Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
How do I find a model number for a MCculloch chain saw?
There are now markings Except for a number stamped into the body on the bottom side. The number is D44-13378. This is the only number or marking that I can find. I can tell you that is is pretty old, there are not any plastic parts.It is made of alum and steel. the bar is maby a 20 or 22. Any info Please
Someone was kind enough to give me the info without trying to scam me out of money.
Posted on Feb 09, 2009
Model number(D-44) with balance of the serial number...It was offered between 1957 and 1959. I have a S-44 model... You should consider converting sprocket to accomodate a 3/8" or .404 in. pitch chain.. Original 7/16" pitch no longer available..
Posted on Jun 09, 2009
  • zigger131973
    zigger131973 Jun 18, 2012
    Hey Bro..I also have this S-44 McMonster but your comment was cut short on here so I could'nt tell what year you might've said it was made. I need an electrical rebuild cause this is one of my fav saws & I've got alot of time invested to just give up now. Where should I go with questions & for parts?...
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 | Firearms
How do you set TDC?
Yes, there's timing marks on all engines. You'll find a mark on the harmonic balancer that the pullys bolt to on crankshaft. Other mark is on a tab bolted to the engine to one side of the balancer. There's a TDC mark stamped into this tab for Top Dead Center of the #1 cylinder. Place these to marks in alignment and your there.
Sep 24, 2014 | Cars & Trucks
Kawasaki main bearings part number
There are a few different sizes of bearings so a part number cannot be given.
In order to work out which bearing sizes will be needed you need to look at the code markings that are stamped onto your crankshaft and crankcases.
each bearing size is worked out from the combination of these two marks.At the very least you will require a manual to show you where each mark is and what sizes each combination means...
May 23, 2012 | kawasaki Motorcycles
How do I set the time on a philippe starck ph1110? There aren't any buttons to push...
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker
Dec 30, 2011 | Watches
Description on jfp1&2
The wire tips generally have their use stamped on the jumper attachment. Any way green-white is for start-up, red-white for reset and others should have one black wire which are for the LED's. The speaker wire is usually traceable. If u had USB connectors it does not matter in what order you put them, except that they should be perpendicular from the bottom side of the MB....sodeep
Mar 08, 2009 | Intel Motherboard
Instruction Manual
Espresso Makers Recall 2/16/2006 12:49:35 PM Krups recalls about 2,100 Orchestro Espresso Makers. The electrical connectors in the espresso machine can erode, posing a fire hazard. The recalled espresso makers are black and silver and make two cups of espresso at once. The word "KRUPS" is printed on the front. The model number and factory mark are stamped on a silver sticker on the bottom of the machine. The following are the recalled models: model number 889-45 and factory mark F8894556; and model number 890-41 and factory mark F8904156. Sold at department stores and independent specialty stores nationwide from January 1999 through November 2005 for about $850. Call Krups at 1-866-832-7690 or visit www.krupsrecall.com for assistance. Source: Consumer Product Safety Commission -- Marla Marino , Tampa Tribune
Jul 06, 2007 | Krups Orchestro 890-41 Coffee Maker,...
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
754 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
