Question about Gigabyte Matx Intel G31 775 DDR2-800 Motherboard
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : it_mid@yahoo.com
    Problem Solver:
  • 7 Answers
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Posted on Mar 13, 2009
  • 1,031 Answers
ECS G31T-M motherboard features the Intel Bearlake G31 and ICH7 chipsets, by supporting the latest Wolfdale, Core 2 Quad and Core 2 Duo processors; ECS G31T-M brings outstanding performance and provides solider price. G31T-M supports Intel 45nm Core 2 Duo and Core 2 Quad processors.
Specifications:
  • CPU:
    - LGA775 socket for latest Intel Core 2 Quad/Core 2 Duo / Pentium Dual-core (E21xx series)/Celeron 4xx processors
    - Supports Intel 45nm Core 2 Quad(Yorkfield) and Core2 Duo(Wolfdale) series processors. (please refer to the CPU support list for more detail)
    - FSB 1333/1066/800 MHz
    - G31T-M is capable to support Core 2 Quad Q6700 G0 and Q6600 G0
  • CHIPSET: Intel G31 & ICH7
    - North Bridge: Intel G31
    - South Bridge: Intel ICH7
  • GRAPHICS:
    - Integrated Intel Graphics Media Accelerator 3100 (GMA3100)
    - Max Dynamic Video Memory : 287MB (Vista) / 384MB (XP)
  • MEMORY:
    - Dual-channel DDR2 memory architecture
    - 2 x 240-pin DDR2 DIMM socket support up to 4 GB
    - Support DDR2 800/667 DDR SDRAM
  • EXPANSION SLOT:
    - 1 x PCI Express x16 slot
    - 1 x PCI Express x1 slot
    - 2 x PCI slots
  • STORAGE:
    - Supported by IntelICH7
    - 2 x Ultra DMA100/66 devices
    - 4 x Serial ATA2 devices
  • AUDIO: Realtek ALC662 6-channel HD audio CODEC
  • LAN: Realtek RTL8101E 10/100 LAN (co-lay RTL 8111B GigaLAN)
  • REAR PANEL I/O:
    - 1 x PS/2 keyboard & PS/2 mouse connectors
    - 4 x USB ports
    - 1 x VGA port
    - 1 x Serial port (COM1)
    - 1 x RJ45 LAN connector
    - 1 x Audio port
  • INTERNAL I/O CONNECTORS & HEADERS:
    - 1 x 24-pin ATX Power Supply connector
    - 1 x 4-pin ATX 12V connector
    - 1 x FDD connector supports two 360K~2.88MB FDDs
    - 4 x Serial ATA connectors
    - 2 x USB 2.0 headers support additional 4 USB Ports
    - 1 x Clear CMOS header
    - 1 x Front panel header
    - 1 x Front panel audio header
    - 1 x LPT1 header
    - 1 x Speaker header
    - 1 x SPDIF out header
    - CD in header
    - CPUFAN/SYSFAN connectors
  • SYSTEM BIOS:
    - AMI BIOS with 8Mb SPI ROM
    - Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
    - Supports ACPI revision 1.0 specification
  • FORM FACTOR: Micro-ATX Size, 244mm*200mm
BACK TO TOP
Posted on Feb 09, 2009
  • Starnley Johnwells
    Starnley Johnwells Feb 09, 2009
    -you just cannot
    mix and match the RAM speeds.
    As far as ram goes, ALL DDR2 Sdram ram sticks are the same length, no matter who
    makes them. your (Motherboard) can support PC2-5300 ram. It's also
    stated as PC-5300. Manufacturers differ with how they state it. When you see
    PC2-5300 you KNOW it's DDR2 ram.
No display in gigabyte g31m-es2l
Hello try to download the manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=3485#manual
You need adobe reader, to read the content.
Check all the power connections again, and the power supply for fault.
It may be there is nothing wrong with your motherboard. Often time, on-board graphics will be disabled with a discrete graphic card is installed. Check your motherboard manual to see if this is the case. You may also be able to find a setting in your system BIOS that allows you to enable the on-board graphics even if a discrete graphics card is installed.
Try also to reset the bios, by removing the cmos battery, and insert it again.
You can also try to add a graphic card, on the mainboard, in the blue PCI Express x16 slot.
Just make sure you have the driver, for your windows system.
Good luck
Mar 24, 2013 | Computers & Internet
I can't find AGP aperture size in Integrated Peripherals
Hello the manual can be downloaded here:
http://www.gigabyte.com/products/product-page.aspx?pid=3471#manual
Adobe reader, is needed to read the content.
My advice is to install a better graphic card, on the mainboard.
The mainboard has PCI-e socket.
This will give a much better performance.
ATI/AMD makes very good graphic cards.
Good luck
Feb 04, 2013 | Gigabyte Computers & Internet
GA-G31M-ES2L supports 2TB Internal Hard Disk
You probably just need to format the drive so you can use it.
The harddrive where windows is installed on must be connectet to sata 0 or 1. port
The drive you have mounted can you connect to the sata 2 port.
If the bios sees it its ok.
Here is some youtube video:
http://www.youtube.com/results?search_query=how+to+format+a+drive&oq=format+a+drive&gs_l=youtube.1.0.0i5l6.2190.7786.0.11662.14.14.0.0.0.0.136.1465.8j6.14.0...0.0...1ac.1.jazllrVg7G8
This shows you how to format the drive.But it depends on your windows system
Good luck
Nov 24, 2012 | Gigabyte GIGA-BYTE GA-G31M-ES2L Desktop...
Giga g31m-es2l motherboard pc resets after running for several minutes
First check the timing of turnoff then Right Click on Desktop -Properties-Screen Saver-Power Button- Set All NEVER
Jun 08, 2012 | Gigabyte GIGA-BYTE GA-G31M-ES2L Desktop...
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
I have a Gigabyte G31M-ES2L mainboard. I cannot get front panel jack to work.
Download the manual from Gigabytes site and refer to the schematic of the board that will show you how to place the jumpers on the correct pins
Dec 25, 2010 | Gigabyte GA-G31M-ES2L Motherboard
I need a sound driver for pc my BIOS Version : G31M-ES2L FG plz tell me right driver for my fc.
Your sound chipset "Realtek Azalia audio chip" for MainBoard G31M-ES2L
You have not mention which operating you are using?
You can search for your Audio drivers at Gigabyte Support Site, HERE.
Hope it helps.
Oct 08, 2010 | Computers & Internet
G31 motherboard lan driver is not installed
You dont have to I supposed but I would install it if I was you.
Mar 27, 2010 | Gigabyte GA-G31M-ES2L Motherboard
Gigabyte Matx Intel G31 775 DDR2-800 Motherboard Logo
865 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
