hahahaha ive done this myself and scratched my head for hours the first time it happened to me in the shop there is a seting for mirror image or screen flip if not then you need to go into the service menu
Hit menu on the remote
Tap right to enter the full menu
Scroll down to sound
Tap right and select Advanced Audio Settings
Scroll down and highlight the Balance slider, make sure it is on 0
Enter 1969 on your remote
The menu will disappear and a green "M" will appear at the top left
Hit menu on the remote, this time a service menu will appear
then other settigns scaler output and make sure its set to normal
Hello that's a 2010 model set. It sounds like the y sustain board is failing (part # EBR61855101), it usually starts with bad connections on it. A screen shot would be helpful...thanks
you will find your driver here (http://www.nodevice.com/driver/company/Motorola.html) then Step One (Clear all other profiles on the phone to avoid confusion):
- Turn On Phone
- Click the Menu Button at the top left corner of the screen
That should bring up the icons for all the applications
- Tap the Setup Button
- Scroll Down to Data Network
- Click Data Network
Internet Profile Page appears
- Delete all profiles on the page Step Two (Clear all other profiles on the built in browser):
Note: My browser on this phone is called Monternet, I picked up
the chinese version, so it might be called something different.
- Tap the Menu button on the top left corner of the screen
- Tap the browser icon, Monternet
This opens the browser
- Tap the three lines on the button right corner of the screen
- Tap Setup
Which brings up another menu
- Tap Profiles
Profiles screen appears
i had the same problem but it was blue tint shortly after the ds would turn on flash then turn off turned out to be the wire ribbon to top screen:: needed new top screen!!
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
