Question about HP Pavilion dv1000 Notebook
Screen Black can barely see images when boot up
While playing Bejeweled, screen completely disappeared and on reboot  can barely see images.  Not sure what to do from here.  Cannot see anything!  Screen black!
I have the same problem but with a HP Pavilion dv1000. Anyone out there have a easy solution such as replacing the lcd bulb and how hard this is to replace.
Thanks
  • bobilichetti Feb 09, 2009
    My display screen on my hp dv1000 laptop went black. I see a very light image in the background, but can't read it. When I connect an external monitor, it works o.k.
    Sergeant:
    Champion:
  • 237 Answers
Well seems like the lcd has lost or the video card has an issue easy way to find out is to hook it up to a monitor and if the pitcure comes out fine then its your lcd screen and if it appears the same then its your video card.
Posted on Feb 10, 2009
Screen driver problem notebook
Might be a hardware problem as well. To make sure it is not, boot to "VGA mode" (see below), keeping the external monitor disconnected, and see if the problem is still there on the laptop screen. If the problem disappears, then it's more than likely that a driver update will solve your issue. If this is the case, uninstall the driver for your graphic card, download the latest one from the manufacturer's website and install it. If not, then you need a more in-depth look, maybe you have a faulty LCD display.
To boot to VGA mode, press "F8" repeatedly while rebooting your computer and select the appropriate choice from the black and white bootloader screen that will appear.
Sep 10, 2014 | Dell Computers & Internet
Black screen
The game has probably screwed up the configuration. They do sometimes.
Press the power button and just before the machine tries to boot press the F8 key. That should allow you to restore or repair your machine.If there is absolutely no display, get it repaired under warranty.
Oct 25, 2013 | Acer C7 Chromebook
NF110 Netbook shows black screen and at top says 'operating system not found' Can you help?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. . Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 18, 2012 | Computers & Internet
SyncMaster 753S (Ivory) 17" CRT Monitor: I can't play the game Bejeweled Twist on this moni...
for an excellent card that is a weird problem. i once had somewhat the same problem - pocket tank just wont play. i changed the screen refresh rate to 60 Hz n evrything was ok. u need to check ur graphic settings. resolution and refresh rates. sometimes lower end games just wont play on high graphic settings.
May 18, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
The graphic software failed. no display
When you turn the computer on, do you see the HP logo?
If you don't, keep the computer on and try holding the computer screen under an overhead light at an angle. If you see a faint image of anything on your monitor, then the lights in your screen went bad. A new screen can range $100-$200 on eBay, and can be changed out easily with a small Phillips screw driver.
If you can see the HP logo, it's a driver problem. If this is the case, start the computer in Safe Mode by performing the following steps.
1. Make sure the computer is turned off.
2. Wait for the HP logo disappears and start pressing "F8" repeatedly.
3. A menu will appear. Select "Safe Mode" and let it boot up to the desktop.
4. Once at the desktop, hold down the "Windows Logo" key on the keyboard and press "r". A dialog will pop up.
5. Type "devmgmt.msc" without the quotation marks and click ok.
6. Click the "+" next to "Display adapters".
7. Right-click each entry under "Display adapters" and select "Uninstall" Click OK on the box to confirm. Don't worry, Windows will reinstall it after a reboot.
8. Once all entries are removed from "Display adapters", the category will disappear from Device Manager. Reboot the computer and start it normally.
9. Your screen will probably still be big and blurry. Log into Windows and adjust your resolution to fit your screen. If you select the wrong resolution, and your screen goes black or does not fit, DO NOT PRESS ANYTHING or you will be going back to step 1. The computer will revert back to the old setting after 15 seconds.
10. Once you figure out the right resolution setting, reboot one more time to make sure that the settings took effect, and you can use your computer once again. :)
Oct 25, 2009 | HP Pavilion dv6000z Notebook
My Asus eee PC fails to boot
Reboot the system
Press F8 at boot startup. In the boot menu
Choose Last Known Good Configuration. If this doesn't work
Try Safe Mode
Go to Device Manager
Roll Back any new driver you've installed
and/or
Go to Add/Remove programs
Unistall any new software you've installed
Mar 31, 2009 | ASUS Eee PC 701 Notebook
Toshiba psa70u Black screen
try to boot in last good known configuration.issue might be with video card check it.
Jan 15, 2009 | Toshiba NTBK|A70-S249 PSA70U-0CU00F PC...
Sony vaio screen dark then light
might be going into a powersave after it boots...try checking the power options
Feb 28, 2008 | Sony VAIO PCG-K35 Notebook
One of four things possible, bad lcd bulb, bad inverter that powers the bulb, or bad mainboard that powers the inverter (rare problem).... and sometimes, bad lcd cable, also rare.
To test, you need a good bulb to plug into this inverter and see if it lights. If it doesn't, then your problem is most likely a bad inverter board. Simply shop online somewhere like eBay to find a replacement. Generally they cost around $30 USD shipped. And you can find it located in the lid, at the bottom of the lcd. You will need to remove any screws in the plastic bezels and carefully pop the bezel off to gain access to it.
One other thing I should mention, I have seen some laptops that have an lcd cutoff switch, or hibernate switch. When you close the lids, its will either put the laptop into a standby state, or it will simply turn the backlight off on the lcd. I've seen those switches get stuck. Note - not all laptops have them.
Oct 23, 2007 | HP Pavilion ze2000 Notebook
HP Pavilion dv1000 Notebook Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
