INSTRUCTIONS REQUIRED TECHNICS SM-ZS35
HI
I HAVE PURCHASED A LOVELY PIANO, AND IT HAS THIS BOX CONNECTED TO IT.
YOU CAN LISTEN TO PRE RECORDED PIANO TUNES, AND AM ABLE TO RECORD ME PLAYING AMONGST OTHER THINGS.
THE MODEL NO. IS TECHNICS SM-ZS35I AM TRYING TO FIND INSTRUCTIONS FOR THIS DEVICE, OF WHICH I WAS TOLD IS WORTH ABOUT AUD$4000???
I CAN PLAY SILENT MODE ON MY PIANO,AND WEAR THE HEADPHONES, SO I DONT DISTURB OTHERS, BUT I DONT KNOW HOW TO USE IT.
.ARE YOU ABLE TO ASSIST WITH INSTRUCTIONS PLEASE???
THANKS HEAPS
WILMA
  • 744 Answers
Hello Sir, just open the ups, and you can see the battery inside. after you open, pull out the battery, then look for the voltage rating, it is located on the battery itself
thank u,
Posted on Feb 09, 2009
HI everyone I've got several UPS Eaton EX 3000 installed in solar farms and ALL of them are malfunction
call the ups engineers for an answer to the problem when connected to solar power
there may be a problem in that solar panels produce various voltages during the day ( depending on the cloud coverage ) and the ups requires a reasonably steady input voltage to operate properly
I have found the eaton ups product to reliable so the suggestion to talk with the engineers to ensure that the system is compatible with the solar set up would be to your advantage
Jun 21, 2016 | Eaton Electrical Eaton Ex 3000 Rt 3u Xl...
Why doesn't it work?
The battery was in a discharged state for too long and now is unable to charge. The cost of a replacement battery suggests it would be wiser to return the unit, if possible, or discard it.
Jun 25, 2015 | Computers & Internet
I have a Max ER2100 Electronic Time Recorder where can I find an instructional manual?
Hi kevin Here's the manual for the er-2100 Electronic Time Recorder.
Iam sorry for the quality on the pictures but i dont have a scanner,,,,anyway i hope this helps you.
http://imageshack.us/g/716/img1500vi.jpg/
Sep 30, 2011 | The Times Max ER-1500 Electronic Time...
I have model G1010USB battery backup and it has been plugged in for more than 48 hours and the battery capacity has never changed and showed it the battery is charged up or not it, the boxes just stay...
Is this unit new or used? Either way, the first thing to check is if the battery is plugged in. UPS units are shipped with one of the battery leads disconnected for safety purposes. Please remove the front plastic bezel and verify the battery is plugged in. If it is new, and you followed the instructions correctly, you could have a bad battery or charging unit in the UPS. Please contact technical support for the manufacturer.
If you have a used UPS, disconnect the battery connections and use a multimeter to check for existing voltage on the battery. If it is completely dead after a charge cycle, it is quite possible the battery is bad and needs replacement.
Mar 05, 2011 | Tripp Lite HT1000UPS (037332125262) UPS...
I have a problem, when i switch on the UPS, the red "X" comes on, the first and third battery LED stays on. I opened the unit, (out of warrantee) and on the Control Panel there is a red led...
HI
IT MAY REQUIRE new battery..
p/n , battery RBC44
this UPS has
Pre-Installed SmartSlot™ Cards Ap9619, look at service manual .. see link below http://www.apcmedia.com/salestools/ASTE-6Z8LL8_R12_EN.pdf if this helped you, please rate me with 4 star
Nov 02, 2010 | APC Smart-UPS® RT 5000VA UPS System
Unit is dead out of the box
I would not bother, just call the dealer and get a new one under warranty.
Aug 25, 2009 | Tripp Lite OmniSmart® OMNI900LCD...
Maxtor Portable Hard Drive 250GB
Hello Robbie.
Basically all you do is drag and drop. If you open up the drive (By double clicking it) then just drag the files you wish to store right into the drive and hey presto your done let them copy over which will take time depending on how many files you are sending over.
Good luck please dont hesitate to get back to me Robbie
Carl
Dec 01, 2008 | Computers & Internet
How to use the Medion Digital Notepad
With my medion digital notebookproblems with the pen instead of writing left to right, it rights on the right to the bottom of the page on the right can you help please as well
Jan 02, 2008 | Computers & Internet
Installation for canon pixma ip 1500
Hey you again, you rated me yesterday Inappropriate. Actually, fixya expert afraid to give some solution because you will rated us Inappropriate even the problem is came from you where you was not clearly stated your problem.
Ok, but anyway I am still to help you, Is it the problem goes to the manual installation you need or the driver instead?
Printers used to be the bugbear of computer users. They were difficult to set up and ornery in operation. That's no longer the case and it's likely you'll have no problems getting your printer up and running. This is particularly the case if your printer comes packaged with your computer system or if you stick to well-known brands such as Hewlett-Packard, Epson, Lexmark and Canon.
Connecting a printer involves four steps:
  1. Unpacking your printer, removing any packaging material and installing the ink or toner cartridge. Refer to your printer's instructions to guide you.
  2. Connecting the printer cable to the printer and to the back of your computer.
  3. Connecting the printer's power cord to a power outlet.
  4. Installing the printer driver and any additional software. The printer driver is a piece of software that tells your computer how to interact with your printer.
If your printer comes as part of your system, you may find that its driver is already installed. In that case, all you'll need to do is unpack it, connect the printer cable and power cord and switch on your computer.
geekgirl.tip: Get a cable One word of warning: Make sure you purchase a printer cable! Often, this is not included in your computer system, despite it being an essential item. You'll need the correct type of cable for your printer: If it's a USB-enabled printer, you need a USB cable (note, the new USB 2 cables work with older USB 1 printers, too; so if in doubt, get a USB 2 cable); if it's a parallel printer, you'll need a parallel cable.
Make sure you get a cable long enough to reach easily from your printer to your computer. However, you should avoid cables longer than 10', because long cables can cause problems with communication between printer and computer. Try to position your printer so a 6' (or shorter) cable can make the connection.
Follow the wizard If your printer's software has not been pre-installed, read any installation instructions that accompany your printer and follow those instructions. If no instructions are provided, follow this procedure:
(Note: This procedure applies to printers which use a parallel connection. If your printer uses a USB connection, you should connect it while Windows is running and it will be recognised.)
  1. Make sure you have your original Windows CD-ROM handy. You may need it.
  2. Switch the computer off.
  3. Connect the parallel printer cable to your computer.
  4. Connect the printer's power cord to a power outlet.
  5. Switch on the printer and the computer.
  6. In most cases, Windows will detect that you've attached a new hardware device and it will launch the Add Hardware Wizard and attempt to search for the appropriate software. If the wizard doesn't launch and Windows appears to ignore your printer, you can launch the Add Printer wizard yourself by clicking the Start button, selecting Control Panel, clicking Printers And Other Hardware, and then clicking Add Printer.
  7. If the printer is directly connected to your computer, select the Local Printer Attached To This Computer option. If you will be connecting to the printer via a network connection, select the Network Printer option, then click Next.
  8. The wizard will first try to search for any Plug and Play devices (these are components that should, by rights, automatically notify Windows when they're first connected). If the wizard discovers your printer, it will display further instructions to complete the installation. You may need to restart your system to finish.
Nov 23, 2007 | Computers & Internet
Computers & Internet Logo
153 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
