Question about Sony VAIO PCV-W600G PC Desktop
Semicolon problem My Sony VAIO started producing random semicolons when I type anywhere. Sometimes the semicolon keeps repeating when the computer is; just sitting still. Do y;ou have any ideas about what the problem could be and how ;I c;an fix it?
    Habit-Forming:
  • 34 Answers
Have you tried restoring the system to original manufacturer's default from the restore CD? also before you do that try to get another keyboard and see if it happens with a different keyboard, it might be the key that is stuck or really sensative.
if you don't have the system restore disk, you may find it at the Sony.com technical support website for this specific workstation.
Posted on Feb 12, 2009
Logitech keyboard had been working fine. Now the keys for symbols on the number keys, and for colon, semicolon, etc. and what gets typed is different. I can not access most symbols.
Replace it. Keyboards use timing signals to perform operations. If your keyboard looses a sectional functionality, they have to be replaced.
Feb 17, 2017 | Logitech Computers & Internet
Pelco dx7000 password
To reset the password for the DX7000 follow these steps: Reboot the system During the boot process, before "Starting Windows" message comes up, press the F8 key repeatedly to enter Safe Mode When the boot options menu comes up, select boot to command prompt only If you get the scan disk screen, you've gone too far and have to reboot. At the command prompt "C:\>" type cd windows and press enter. At the prompt C:\WINDOWS>" type edit system.ini and press enter. When the edit screen opens up, scroll down to the line beginning with the word "shell" Insert a semicolon (;) before the word shell = ;shell Save the file, exit, then reboot the system (You may have to hit ALT on the keyboard to get the File menu to come up) Press ALT+F followed by X and select Yes to the save and exit prompt Press CTRL+ALT+DEL to reboot. The system should now boot to a regular desktop, edit the system registry: Click on the Start button Select Run In the Open field, type in REGEDIT, then click on OK Find the password entry and delete the password: Double click on HKEY_CURRENT_USER Double click on SOFTWARE Double click CyberNetic Double click DVR Double click 1.0 On the right-hand side, locate the word Password and double click it Delete the contents of the Value Data field and click OK Close the regedit window Make the system bootable into DX7000 software: Click START Select Run In the Open field, type SYSEDIT then click OK Click on the SYSTEM.INI window within the System Configuration Editor window Locate the SHELL statement and remove the semicolon that was placed there earlier Close the System Configuration Editor window Click OK when it prompts you to save changes made to SYSTEM.INI file Restart the system (Click START > SHUT DOWN > RESTART) Click OK
Apr 01, 2012 | Pelco DX1000
How to pprogram a java language
download java compiler from http://www.oracle.com/technetwork/java/javase/downloads/index.html
Go where you install your java, default Path is "C:\Program Files\Java"
in Java Folder open folder jdk then open bin copy its directory located at the address bar then
Right Click My Comuter > left click Properties > Advance > Environment Variables > on System Variables find Path then click it then click Edit
insert a semicolon " ; " on the end of the textbox (if already have don't add semicolon) then paste the directory you copy...
you can now create your Java Code....
to Compile and Run it...
open command promt ( to open click start > run > type cmd )
go to directory where you save your java code..
(ex. if your Directory is "D:\Java Folder" then type "cd.." press Enter repeat "cd.." until "C:\>" is remaining then type "D:" press enter then type "cd Java Folder" then press Enter type "javac (name of your javacode).java " Press Enter (if there is an error correct your java code) if no type "java (name of your javacode)" there you can run your Java Code
Aug 04, 2011 | Microsoft Windows XP Professional for PC
Hi! Today when I restarted my netbook from sleep, it decided that it would type semicolons when I hit the shift button and colons when I hit the delete button. Typing letters also gave intermitant...
There is probably a foreign object beneath the key cap and the keyboard membrane. Use a flashlight to see if there is something visible between the keys. If not, the key cap ( the part you actually type on ) can be removed CAREFULLY to see if there is a problem, but I would recommend a trained professional do this part, as the components involved in keyboards can be small and easy to break or lose.
Mar 05, 2011 | Acer Computers & Internet
In c language can i print my name without using semicolons???
you need to use an endline function when outputting to the screen, example:
cout << "my name" << endl;
Mar 02, 2009 | Microsoft Windows XP Professional
How to enter data for SD mode for FX-570 series
I BOUGHT ASENTRY ELECTRONIC COMBONATION SAF FRON A FRE\IEND WHO LOSAT EVERERY TNIMH NECESSASY TO RESET TH CUMBO . ISTHRERE ANY W-AY POSSIBIBLE TO OPEH ANDCHANGE THE NEW COMBOM[NATION
Feb 10, 2009 | Casio FX-115ES Scientific Calculator
When i log on a message........device monitor application has encountered a problem and needs to close.........this is causing problems for me as some things (like messenger doesnt work)
Try these steps:
  1. Download the printer driver from the Lexmark website.
  2. Unzip the files but do NOT install the printer using the downloaded driver. Cancel the installation that starts.
  3. Go to the C drive and open the LXK.... folder.
  4. Go to driver and then to win Xp_2k.
  5. Open the View menu and select Details. Details of the file are displayed in columns in the right-side pane. Look for the SETUP INFORMATION file in the Type column.
  6. Open the notepad file in the Name column to its left.
  7. Click Edit, Find and look for the entry that begins:
    LanguageMonitor=
  8. Add a semicolon (;) at the beginning of the entry. NOTE: The semicolon disables the entry.
  9. There are two instances of the word LanguageMonitor in the file. You will need to place a semicolon (;) before itin both places. (Use Edit, Find Next to locate the second instance of the word.)
  10. Click File and select Save. Close the notepad file.
  11. Now look for the CONFIGURATION SETTINGS file in the Type column. Repeat steps 6 through 10 above with this file also.
  12. Go to the Control Panel and select Printers and Faxes.
  13. Open Add Printer. When the Browse option appears, follow the steps for installing the printer using the INF file from the C drive.
  14. DO NOT try to print a test page as a communication error may result. First you need to change the spooler settings. Do the following:
    1. Go to the Control Panel and double-click on the Printers folder.
    2. Right-click on the printer icon and select Properties.
    3. Click the Advanced tab and select Print Processor.
    4. Change the Print Processor to Winprint and the Default Data Type to Raw.
    5. Click Apply and OK.
    6. Attempt to print a document.
Good luck..
Dec 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Olympus 3000 Zoom digital camera
You have to edit the file:
c:\windows\inf\srusbusd.inf
You'll have to remove two semicolons.
The section:
[Manufacturer]
;%MfgNikon%=ModelsNikon
;%MfgEpson%=ModelsEpson
remove this semicolon=>;%MfgOlympus%=ModelsOlympus
Must become:
[Manufacturer]
And
The section:
[ModelsOlympus]
remove this semicolon=>;%USB\VID_07B4&PID_0100.Device%=Olympus,
must become:
[ModelsOlympus]
%USB\VID_07B4&PID_0100.Device%=Olympus, USB\VID_07B4&PID_0100
After this, if you have already the Olympus C-xxxx in your Device Manager,
uninstall it and run again the new hardware wizard. Let Windows XP find the
correct driver. Windows will attempt to frighten you with a catastrophe
prophecy. Just ignore it and go on (it works perfectly).
You're done. Now your Windows XP will see your Olympus C-XXXX Zoom
without any additional software.
Jun 05, 2008 | Olympus C-3000 Zoom Digital Camera
Sony VAIO PCV-W600G PC Desktop Logo
159 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
