Question about Sentry Fireproof Safe
I have a protocol safe. A and B on the keypad. I cant remember
I cannot remember how to enter my numerical code...is it three or four digits? do i touch the "A" or "B" during the process. The pad beeps andlights...i just cannot get the sequence correct.
Found the keys and directions
Posted on Feb 09, 2009
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    My safe, a Cathedral EA15 Will not lock. Any suggestions people?
    Instructions
    1. 1
      Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
    2. 2
      Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
    Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
    1. 1
      Enter your code to open the safe.
    2. 2
      Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
    3. 3
      Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
    1. 1
      Use your code to open the electronic digital safe's door.
    2. 2
      Locate and remove the battery cover on the inside of the door.
    3. 3
      Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
    4. 4
      Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
    Feb 08, 2015 | Locks & Locksmithing
    How do i change the numerical code?
    How to change or program code on your Craftsman Liftmaster keyless keypad made by Chamberlain.
    1. Program using the "Learn" Button
    2.
    Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
    3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
    Program using the Multi-Function Door Control
    NOTE: This method requires two people if the Keyless Entry is already mounted outside the garage.
    1. Enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold ENTER.
    2. While holding the ENTER button, press and hold the LIGHT button on the Multi-Function Door Control. Both of these should now be held down at the same time.
    3. Continue holding the ENTER and LIGHT buttons while you press the push bar on the Multi-Function Door Control (all three buttons are held).
    4. Release buttons when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
    Change an Existing, Known PIN
    If the existing PIN is known, it may be changed by one person without using a ladder.
    1. Press the four buttons for the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
    2. Press the new 4-digit PIN you have chosen, then press ENTER.
    The motor unit lights will blink once when the PIN has been learned.
    Test by pressing the new PIN, then press ENTER. The door should move.
    Your new Keyless Entry must be programmed to operate your garage door opener
    May 24, 2011 | liftmaster 977lm 976lm Liftmaster...
    Have my code but cant remember how to enter it
    Hi, it depends on which model your safe is. If you goto the sentry safe website you can download the manual for your particular safe. Link to their website:
    http://www.sentrysafe.com/CustomerCare/Product_Manuals
    Feb 12, 2011 | Safe International Digital Keypad...
    Sears Craftsman key pad is about 20 years old. Need to re-program code. I know you hit a few numbers then the 4 digit code but I can't remember the #'s.
    If it is a wireless keypad do this:
    Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
    If it is hardwired do this:
    To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
    Oct 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
    How to give ip address to workcentre m133 network printer
    : You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
    Jun 09, 2009 | Xerox WorkCentre M15i Laser Printer
    Can't open my Protocol Home Safe - Electronic Keypad Entry
    Hi I have a Sure Safe electronic key pad safe, i have owned for about 5 years we have moved house and it was placed in storage.
    For the life of me i can not remember the code i have tried endless times !! is there a way to get in or do i take it to a professional.
    Jan 11, 2009 | Sentry Fireproof Safe
    Philips DVDR3455/37 (160 GB) DVD Recorder / HDD Recorder
    i spent hours looking for this... here it is
    Use the numeric keypad 0-9 to enter your four-digit pin code.
    • If you forget your four-digit pin code, the default password is 3308.
    Apr 29, 2008 | Philips DVDR3455H/37B
    Errors list : 46, 50, A1
    CP315C/310CN/120C/115C/117C/110C
    (1) Press the (1) Press the
    Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
    enter the maintenance mode. enter the maintenance mode.
    (2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
    Set keys.* Set keys .*
    (*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
    display the numerical code to be entered and then press the display the numerical code to be entered and then press the
    Set key. Set key. Repeat this operation for each Repeat this operation for each
    numerical code.) numerical code.)
    (3) Press the (3) Press the
    Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
    (4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
    Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
    (5) Press the (5) Press the
    Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
    (6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
    Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
    Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
    How to unlock LG VX4400
    Many people never program a password code to "Unlock" this phone, but can lock themselves out by pressing the # key for more than three seconds. I know, it happened to me when I was out of town and needed the phone to work! Anyway, press the button to the right of the large round button at the top of the keypad, you will get a prompt to enter the four digit "Unlock" code. The default from Verizon, and most likely the factory default from LG, is the last four digits of your cell number. Did this work for you too?
    Mr Dennis
    Nov 27, 2007 | LG VX4400
    Sentry Fireproof Safe Logo
    116 people viewed this question
    Top Sentry Home Security Experts
    Jim London
    Jim London
    Computer Repairing
    Computer Repairing
    Hannah Johnson
    Level 1 Expert
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
