Question about RCA HD52W59 HDTV Projection Television
Red and Green flicker after replacing FL231
I replaced the blown FL231 fusible link, as it caused the convergence to misalign. I also desoldered and resoldered most of the joints on the flyback. I ran out of desoldering braid, so I added new solder on top of the cold solder. Not a great idea, but I was impatient to get it back up and running.
Well, it's been about a week since I "fixed" the convergence issue, but I am noticing a red and green flicker of the picture. I ran the auto convergence and also manually aligned in the Service Menu, which is pretty close to perfect. The picture looks great besides the flickering of the red and green colors.
Before I tear it open again, should I be looking at something besides the solder joints at the flyback?
  • RCA Master
  • 5,138 Answers
Go to the R/G CRT boards at end of neck of picture tubes resolder socket pinns and Video ICs on the board.
Posted on Feb 16, 2009
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
How do I access the menu to get to the auto convergence setting. My screen has lost its autoconvergence.
Than this RCA DLP tv have convergence fuses.Convergence fuse is dead.U have a soldering iron, desoldering pump or desoldering braid and can u do basic soldering? Replaced convergence fuse FL231 that near the right FBT.The one in the Middle out of the three useally dead.Try Ebay.com to buy the FL231 convergence fuse.
Jan 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
Tv started ghosting in red green and blue
The tv is have a problems call convergence,it dead.U have all the tools like soldering iron,solder and desoldering pump.Know basic soldering?The convergence fuses FL231 three of them on the right side of FBT,a big block of plastic of a flyback transformer.Resoder the FBT,replaced the convergence fuse FL231 in the middle.The Ebay.com sell the convergence fuse.
Aug 25, 2010 | RCA HD52W59 HDTV Projection Television
The picture just changed & the convergence is off with the picture bowing inward on top & bottom of screen & you see the image in red,blue & green. The auto convergence feature in the setup...
U have a soldering iron,solder wick or a desoldering pump,and solders?U know how to do soldering?U can fix this problems like about 20 mins.The convergence fuse part (FL231) is dead.Very common on this model of RCA tvs.U can buy this convergence fuse (FL231) at Ebay.com pretty cheap like $3+ shipping.There 3 small brown or pinkisk sqaure look like caps.The one in the middle is dead.But they're fuses located right side of the Flyback transformer,call a FBT(a big black block of transformer).Resolders the FBT too.
Jun 18, 2010 | RCA HD52W59 HDTV Projection Television
Picture is 3D like with green, red, and bules lines at the top of the screen. It is also cuvred on the top, and bootom of the screen?
Your has probably blown fuse fl231, causing your convergence to go out. This is often a sign of a bad power supply. The fuse is located right next to the power supply. Replace the fuse and check flyback for bad solder joints. I fuse blows again, replace fuse and flyback transformer.
Oct 12, 2009 | RCA Televison & Video
Did you get an aswser on the IC's?
THe rca itc222 chasis has No convergence ics it uses a series of transistors to do the same. YOU replaced the Fl231 fuse and it blew. Did you resolder flyback connections. this is why the fuses blow. check out the article under the tips and tricks section written by me willtab ... see if this helps if not let me know .. i see alot of these at the shop ( i got one right now in front of me with the FL231 probelem LOL) if can let me know i give you help
Sep 15, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WH74 Convergence Problem
Yes i replace that fluse fl231 all the time at the shop. at least two aweek. and the first few i replaced did the same thing. I would send it back to customer and i would get a call that the set had malfuctioned again and convergence gone. It was determined the reason this fuse blows is bad conections on the flyback transformer. The flyback is the big black component with the red wire coming out of the top. if you examine the connections on this component there will more than likely be a ring in the solder. this is caused by the manufacturing process known as LEAD-free solder. THis cause oscillations in that cuicit. like turning it of and on really fast. this is a very small fuse and cant stand up to this. so when you replace this fuse just simply RESolder these connections apply a little amount of solder to these connection. i am confident this will fix your problem.
Sep 10, 2008 | RCA R52WH73 Projection Television
Location of convergence IC's in R52WM24
i have the same problem where is the fusible link i replace 2 boards and a connector (t.v. repair man can and diagnoised the problem but did not fix it)
Feb 02, 2008 | RCA R52WM24 52" HDTV Projection Television
I cannot adjust my convergence
This is a very common problem with the ITC222 chassis. If you cannot access the Convergence Menu (either in Customer or Service Menu), the FL231 fusible link is the culprit. More than likely that is blown, which will cause the Convergence Menu to disappear, "bowing" picture, convergence to be off, and will run as  "tube CRT" mode.
It is also important to check the Flyback transformer and the solder connections below it. If you have a bad connection (i.e. cracked solder), FL231 will blow again and experience the same problems.
Aug 21, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
