Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
'92 softtail 5 speed only has 1st & 2nd gear
Bike only has 1st & 2nd gear no neutral, feels like a lot of play in shifter.
  • focus14841 Feb 10, 2009
    removed transmission top cover. inspected shifter cam, shifter pawl,& related linkage. found the shifter arm spring had snapped.
  • 116 Answers
Probably the snapring on shifting drum pull top cover to inspect
Posted on Jan 02, 2010
  • makeitfast57 Jan 02, 2010
    glad YOU figured out your prob by YOU decideing to remove top cover and inspect
  • Harley Davidson Expert
  • 284 Answers
It will be hard to shift or find neutral if the clutch isn't adjusted right. check your adjustment first.
Posted on Jun 11, 2009
Transmission issues on a 2003 Buell XB9S Lightning.
sounds like shift lever adjustment problem
take it into a service center and have it properly diagnosed and a quote
Sep 09, 2016 | 2003 Buell Lightning XB9S
Can only select 1st neutral an 2nd gear
Hi Meihana and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Shift lever is loose on the shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Can shift above 2nd gear
Wont shift past 2nd gear
Shifting stuck won go past 2nd gear
Apr 06, 2016 | Motorcycles
Hello,i cannot engage 2nd gear and upwards on 1982 xj650 rj model yamaha motor bike .
need to look at internal gear selector, may be bent, or springs damaged
Feb 17, 2013 | 1981 Yamaha XJ 650
2001 Honda VT 1100 C2 Shadow Sabre 1st and second gear is jumping into neutral
Hi, Mike and the usual suspects are:
1. Shifter pawl improperly adjusted.
2. Shifter drum improperly adjusted or damaged.
3. Shifter engaging parts/dogs badly worn or rounded.
4. Shifter forks bent.
5. Damaged gears.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
the infamous 2nd gear popout
Popping out of 2nd Gear
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Jun 29, 2012 | 2001 Honda VT 1100 C2 Shadow Sabre
How to drive?
you can ride the cluthch on a bike un like a car you wont hurt it its oil lubricated constantly, sitting on the bike pull the clutch in with your left hand and click the left foot lever down in to 1st, then learn how to click it back up 1 half movement in to neutral. the neutral light will come on sfter the bike enters neutral. in first gear give the throttle on the right hand a squeeze and pull the clutch in with your left hand put foot gear selector down in to 1 st and begin to release clutch slowly. hold on as bike will engage may be jerky balance yourself! when you get moving stop! by pulling the clutch in and the hand brake as you close the throttle to stop! practice your take off many times some where safe! when you get your balance in 1st gear pick up speed and begin shifting the foot gear selector up in to 2nd gear and practice closing the throttle and breaking to a safe stop. gears are generslly 1st down 1 click 2345 and6th all up from there and neutral is 1 half a click up from 1st between 2nd gear. And dont put it in gear with the kick stand down t may stall on you
hope this helps
May 03, 2011 | Honda CR 500 R Motorcycles
No second gear
The 2nd gear lockout is, a mechanical speed sensing mechanism. It doesn't care if the engine is running. You bypass it by scooting the bike forward, about 5-6 mph, while shifting the transmission into 2nd gear.
Stand on the left side of the bike, with the ignition "ON" and the transmission in neutral.
3 With your right foot on the ground, behind your left foot: place your left foot on the left foot peg, with your toe under the shifter; squeeze in the clutch.
*4.Scoot the bike forward about 5-6 mph, with your right foot, and shift the transmission into 2nd gear, with your left foot. If you accidentally go into 3rd, or some higher gear, you can easily shift back down into 2nd, without further movement of the bike.
5.To start the bike: Apply the choke if the engine is cold. Squeeze in the clutch and push the bike forward, both feet on the ground, about 8-12 mph. Release the clutch until the engine start
As soon as the engine starts: squeeze in the clutch and shift the bike into neutral.
Apr 23, 2011 | Suzuki GSX 750 EF Motorcycles
HOW DO I SHIFT A 2003 KX 250
pull your clutch in on the left handlebar push the shifter lever down and let you clutch out slowly while giveing the bike a lil bit of gas. But if you don't know how to ride i wouldn't be jumping on a kx 250
Sep 20, 2009 | 2003 kawasaki KX 250
Shifter seems to have shifted
just ram the shifter in your booty,.....duh
Dec 31, 2008 | 2003 Toyota Celica
Lands Phones Logo
131 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
