Question about Kenmore Washing Machines
Kenmore washer continully runs
Kenmore 90 series
model is 11026912691
Washing machine will not stop running water. My kenmore fills up with water, and after it starts to agitate, a few seconds pass and the water comes back on and continues to run over.I then have to turn it over to the spin cycle to get the water out before it over flows.I was told to change the pressure switch.I done that and the same problem is there.It did not change anything. Any solutions?
  • 15,935 Answers
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave www.washermd.com
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Hello Friend, Your problem is easily solved. You need to replace the water inlet valve. It's easy to replace the water inlet valve on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, you will be able to gain access to the water inlet valve. Simply remove the hose and wires from valve and replace with new one. Re-install the cabinet, control panel etc. This should solve your problem. Happy to help, Tim.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
HELP ME WITH MY PROBLEM
if water stops when knob pushed in raise console (probably screws under each end cap just pull caps toward you to remove )remove screws lift console ck small hose going to water level switch to be sure it is pushed on ..if water will only shut off when faucet turned off replace fill valve
Dec 12, 2008 | Kenmore 22422 Top Load Washer
KENMORE
ck the drive coupling and the motor start windings
Mar 03, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
67 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
