Question about Conia DVD8500 DVD Player
Any disc put into dvd player shows up as BAD DISC
I have a Conia CLCD1930 DVD which has worked very well for over a year.Now when I put in any disc it is loading for a long time then comes up as BAD DISC
    President:
  • 2,110 Answers
Your DVD player lens needs to be cleaned by a lens cleaner...
Posted on Feb 09, 2009
PCH-DVD 300 says every disc I insert is a "Bad Disc"
First thing to do is clean the lens with a good quailty DVD lens cleaner, it that doesn't work you have a fault, in either the lens or the electronics.
Mar 21, 2010 | Cyberhome CH-DVD 300 DVD Player
Dvd says 'bad disc' - how can I fix this?
I solved this on my CH-DVD 300. The laser slides in and out on two rails. It's supposed to be in the far inside position to load/read a DVD. If it's too far out of position it does not automatically return to the far inside position on startup or eject/load. I manually pushed the laser assembly to the far inside position and now my player is working perfectly again.
The laser was evidently jarred out of position by a mechanical shock, or perhaps the power failed while playing a DVD and left it out of position.
May 29, 2009 | Televison & Video
Dvd stuck in conia clcd1930
To Eject the DVD, my conia clcd1930 needs to be in "DVD" mode. This Mode appears to activate power to the entire DVD module. So the Eject button will only work in this mode.
Feb 19, 2009 | Televison & Video
Conia M580 DVD player has died, cannot open disc tray to retrieve DVD disc from player. Cannot unlatch the disc tray manually, as there's no pin-hole near the disc tray, unlike most (more expensive) DVD...
Easy... follow these instructions
  • unplug from the mains
  • take the cover off (3 screws on back panel, 1 screw each side, sticker on top front)
  • You will see the DVD disk in the player drive
  • Remove the plastic ******** top of the drive - 2 x small phillips screws
  • Lift out the DVD disk.... done.
Oct 31, 2008 | Conia DVD8500 DVD Player
Cyberhome 320 wont load discs
This dvd's fails because a dry capacitors on the alimentation source you need to send to a repair service center.
May 13, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD eating discs
It's obvious that the DVD is stuck in the player. There's only one way to get it out! You have to open the DVD player. If you have never done this before, I don't recommend that you do it.
Apr 17, 2007 | Conia DVD8500 DVD Player
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Dvd player won't play-shows "bad disc" on screen
it did the same thing to me, it started to work again. it may be a memory issue. my koss player started to work again after it was unplugged for a while. Its something to do with the dvd disc not the player. if i find out , i will post again. good luck
Dec 25, 2006 | Koss KS4110 DVD Player
Televison & Video Logo
308 people viewed this question
Top Conia Televison & Video Experts
degroot2940
Are you a Conia Televison and Video Expert? Answer questions, earn points and help others
