Question about Philips VRA611AT VCR
Philips Magnavox vcr flashes 2 & won't stay on
My Philips Magnavox VCR has worked fine for years. Tonight the display is flashing a 2 and it won't stay on. It's wirrring for about 20 seconds then switching off. It won't even eject the VCR that's currently inside it.
  • buttercup523 Feb 09, 2009
    It is model VRZ362AT22
  • cross_eye62 Feb 21, 2009
    I have the same problem. I haven't used the vcr for a while but when I inserted a tape the machine made a noise while loading the tape and then shut off and started flashing a "2". If I turn it back on it shuts off after about 10 seconds. I can't get the tape out of the machine.
SOURCE: Flashing '2' or '1' or '4' when I try and play a tape
The idler on your machine needs to be changed and also the drum head of your machine needs to be clean.tape head cleaners can be bought from any electronic shop.the idler must be changed by qualified techn
Posted on Jan 27, 2007
dodgecharger
  • 254 Answers
SOURCE: Flashing "3" on VR330 front panel
A possible bad sensor, bad mode switch, mechanism gear timing off, or perhaps a missing or incorrect voltage from the power supply may cause this problem. I don't know what the "3" indicates, this may be an error code which would help a technician with the proper literature diagnose. Unfortunately, most modern electronics, VCRs, TVs and such are of the disposeable variety. Costs of repair, if you can even find a service center, are usually not economical. If you by chance have some technical savvy, you might be able to trace the problem down.
Posted on Apr 06, 2007
Shuttle83
  • 1139 Answers
SOURCE: MAGNVOX MWR20V6 VCR WON,T ACCEPT TAPE EJECTS WONT LOAD UP
Hello alhertel,
The old idler wheel has been replaced with gears (cheaper and last longer then the old rubber wheel). What you need to do is to gain access to the loader motor and turn it until the carriage begins to move, once the carriage gets to the top and moves outward you should be able to eject the tape with no problem.
Believe it or not VCRs are throw away technology, since it costs as much to repair one as it does to buy a new one. However, there are a lot of people who still hold on to their VCRs.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 12, 2008
SOURCE: Error 2 on Front Panel
I'm not sure if this is a solution, but it cleared up the problem for me. It turned out there was a loose paper label for the cassette that got stuck inside the VCR with the cassette.
I had to take off the top of the VCR by removing the three screws. I then removed the jammed loose paper and then was able to get the cassette out. The flashing number 2 (whatever that means) went away. The machine seems to be working fine now.
Posted on Dec 25, 2008
MNfisherman
  • 11896 Answers
SOURCE: VCR will not turn on.
Remove top cover of the VCR. Then look near the back where the plug-in and power supply is. There should be a little glass fuse. You should keep that fuse and take it to the store and replace it with same exact one. If your VCR can be self-repaired, than this is the only thing you can try.
Posted on Mar 11, 2009
JULIANFIX
  • 975 Answers
SOURCE: Need owner/operator manual fo Magnavox VRU240AT VHS VCR
go to this link to download manual :
http://www.2instructions.com/search.php?cmarque=MAGNAVOX&modele=MWR20V6 , hope it helps , AJ
Posted on May 16, 2009
Timer light stays flashing all the time how do i get it to go out?
You need to go in the on screen menu and set your clock. This will stop the flashing.
Aug 30, 2014 | Quasar VHQ400 VHS VCR
Can't get my vcr off auto. It keeps flashing and vcr won't shut off. Can't get to the menu long enough to see how to shut it off
Try unplugging the VCR for 20 seconds and plugging it back in. It probably will still flash because the clock needs to be reset but you should be able to turn it on and off.
Feb 21, 2012 | VCRs
I cant record tv through my vcr.
set the vcr up so that you change the chanels through the vcr,,,check the vcr setup menu
May 16, 2009 | Philips VCRs
Mar 11, 2009 | Philips VCRs
Hello alhertel,
I hope this helps,
Thank you,
Shuttle83
Dec 12, 2008 | Philips VRA611AT VCR
Apr 19, 2008 | Philips VR620CAT VCR
Problem with philips magnavox vcr
Most Philips/Magnavox VCR uses "PL" to indicate that the unit is on Parental Lock. Push and hold the power button on the remote control and wait for the unit to power up. This should be within 7 seconds.
Additionally, most (but not all) Philips/Magnavox VCRs are sub-contracted to Funai. Pls try here for Funai downloads of user's manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 16, 2008 | VCRs
Vr540 philips
E2 is not an error code. It means that the video tuner is set to EXT2 (Scart input 2)
Press the VCR button on the remote control, and try again.
Nov 17, 2007 | Philips VR540 VHS VCR
Remote control code for Philips VCR & DVD player DVP3340V/17
If you have Dish Network and I suspect if you have Direct TV or a cable providers, you can use your remote for that service provider to find your VCR code. For the Dish you can look in the user's guide on pages 9 and 19 to see how to do a "Device Code Scan" and "Check Device Code".
To Scan: #1: Turn on the device you wish to scan for a code, #2 Press and hold down the button on your Dish remote for that device until all the buttons light up and the specific device button is flashing, #3 Press the blank power button, #4 press the up or down button until until your VCR tuns off, #5 Press the POUND ( # ) key to store the code number and #6 Press the blank power key to turn the device back on.
To Check the Device Code: #1 Press and hold down the device key until all buttons light up and the device button is flashing, next press the POUND ( # ) key TWICE ! The Mode button will flash to code number with a pause between each number, i.e. 5 flashes, pause 3 flaskes, pause one quick flash is 530. Write down this number and you are rady to go !
Nov 16, 2007 | VCRs
Vcr
unplug it for 30 minutes and retry...any luck?
Jun 01, 2007 | Mitsubishi HS-U445 VHS VCR
Philips VRA611AT VCR Logo
1,127 people viewed this question
Top Philips VCRs Experts
Robert McClure
 Grubhead
Grubhead
Are you a Philips VCR Expert? Answer questions, earn points and help others
