Question about iLO LCT32HA36 Television
No Power My iLO LCT32HA36 is not powering on, the red standby light is blinking. i've never seen it blink, so this is strange. when i press the power button on the tv it doesn't do anything no clicks, pings, or buzzes it just won't come on.
  • moayadbaba Feb 11, 2009
    My ilo LCT27HA36 doesn't turn on, I tried rebooting it by shutting off
    the power, but that didn't help. When I hit the power button the red
    stand-by light just blinks.
  • 2,326 Answers
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance
Posted on Feb 21, 2009
    President:
  • 1,077 Answers
It's possible your TV when into protection mode. This happens when a part is burned out inside your TV to prevent further damage.
Try unplugging your TV for 30mins. Then see if the problem still occurs.
If the problem is still there, you may have to take it to a repair shop to diagnose the problem.
Posted on Feb 09, 2009
2001 Sony KP 61V90 61 inch rear projection TV has steady red power/standby light and thus is getting power, but doesn't fully turn on. I've read that this may be a fuse. Suggestions on repair?
Hello. I can help, but please could you tell me how many times the front LED blink?. After connecting and press power, see how many times the LED blink. are you sure the TV model is same as that spelling on your question?. send me your answer and will answer soon. thanks
Aug 14, 2011 | Televison & Video
LCT32HA36 Television does nothing. The standby light does not come on when plugged in.
Check the power source?Yes,than the tv power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 29, 2010 | iLO LCT32HA36 Television
Our iLo LCT32HA36 will not power on. The light will blink red and then stay red..
It may be in the safety shutdown mode due to power supply problem or failed backlight inverter boards.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Oct 21, 2010 | iLO LCT32HA36 Television
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
My TV will only turn off and on. No other
Power light blinks?Ur power board is dead.Replacd the power supply board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 15, 2010 | iLO LCT32HA36 Television
ILo tv
It looks like the power supply failed on your TV. If the LED is solid red or green, it could be some leaky or dry capacitors but if the LED is blinking, the failure is more complicated to repair.
I service these power supplies. If you need more info you can send me an email to jah2mil@hotmail.com
Jun 04, 2008 | iLO LCT32HA36 Television
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
Kd-32fs170
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 24, 2007 | Sony KD-32FS170 32" TV
iLO LCT32HA36 Television Logo
354 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
