Question about Apple iPhone Smartphone
Apple Iphone not turning on?
I have apple iphone 3g. By mistake i spilled some water on it and was unable to turn off the battery as it was blinking and what not. I left the phone near the lamp to dry out and then put it in rice for four -five days to dry out completely. Later i put it to recharge but it never came on. I hooked it up to my computer and in itunes can see my folder and pictures. I was able to update the newere software version on this dead iphone. I m trying to figure out what is that need to be fixed to get the iphone in working condition again. Is it battery that is bad or something else? It's surprising that i can see folder and update the software and restore the phone but unable to start it.
    Problem Solver:
  • 10 Answers
How to Save a Submerged iPhone3G
I have an iPhone 3Gthat has been submerged not once, but four separate times, three of them over a minute(not on purpose of course). The last time was at least 10 minutes, but more likely closerto 20 minutes. I noticed it missing frommy pocket traveling through a shallow swamp on my duck boat, so I didn't even bother lookfor it. I later found it in the bottomof the boat upon pulling the drain plug. It had been submerged under several inches of particularly cold anddirty bilge water the entire time. The point I am tryingto make here is that, the iPhone 3G is a rather resilient device, as far assubmersion in water is concerned. Therefore, it would seem that there is a good chance your device can besaved, even this late in the game.
First, and foremost,is going to be getting device apart, so the inside can dry out. Due to the iPhone 3G's tight and relativelyseamless construction, you can be almost certain there is still water inside.
There are manydecent places on the web to find text, picture, and iPhone-3G-Step-By-Step/id/3302490466">video instructions on disssembly, some may outline reassembly as well. But if you really take your time and don't lose any screws, it is not that bad until the end. Performing a search for "iPhone 3g disassembly" will net you plenty of results ti sort through.
I must warn you that there was one part of thereassembly process that may be rather difficult for some people, which requires avery delicate, yet firm hand. At the time I first attempted this last fall, there were no "how to" instructions on the web for this part of the procedure, however, that may be different now.
To start, you'llneed a small paper clip, a set of small Phillip's-head screwdrivers, a prying tool that needs to be rigid and flat and for thepart mentioned about a thin tweezers, forceps or similar tool. Basically, when you are connecting the final3 connectors that run from the digitizer to the motherboard, you'll find two ofthem relatively easily snap in place. However, the third connection is theshortest, thinnest and most delicate, consisting of a ribbon that needs to bedelicately slid into a snapping connector. The catch is, the covers need to be nearlyclosed together in order for it to reach, it's not fun.
Anyways, I attachedsome good links in the first sentence of paragraph three for you. For the most part just follow the directions,taking the device completely apart and let it dry for a day or so. The digitizer will probably retain some water inside even after drying thedevice from the inside out. The best wayI can describe what it looks like would be a cluster ofopaque-irregularly-shaped "islands" inside your screen. The "water islands" slowly evaporate over a period of weeks tomonths probably from heat produced by the back-light being on, depending on how much is in there.
Posted on Feb 09, 2009
Find flash contact for iphone 3GS
The iPhone 3GS does not have a flash. The iPhone 4 was first model.
Some battery / charging cases (lenmar is one) will have a light that you can turn on independent of the phone. That will be your only option.
Feb 28, 2015 | Apple iPhone 3G Black Smartphone
Iphone 3g stuck on apple logo after jailbreak
hy,??,????????iphone?????,????????????,???????(vipprogrammer.com)????DIY????,?????????,
May 21, 2017 | Apple iPhone 3G
Iphone wont turn on
hold the power button and the home button or change the battery.
Jul 09, 2010 | Apple iPhone Smartphone
My apple iphone 3g will not turn on
My recommendation is if it is still under warranty and has no water damage take it to the Apple Store for replacement. They will look into the earphone jack to be sure there is no water damage and hand you a replacement. Once you get it restore the last backup point with iTunes.
Jan 23, 2010 | Apple iPhone 3G Black Smartphone
IPhone 3g does not work!
Hold in the home button and power button until the apple comes up!!
Jan 12, 2010 | Apple iPhone 3G
I can't get my iPhone 3G to detect other bluetooth devices. Some devices detect it, but are unable to pair with the Iphone 3G. This iPhone 3G bluetooth problem is another one in a chain of iPhone 3G...
The iPhone unfortunately does not pair with just any device, it would be best to check compatibility before purchasing a new peripheral for your iPhone.
Dec 27, 2009 | Apple iPhone 3G
How to insert a sim card into a Apple iPhone 3G 16GB
Remove the battery cover, then remove the battery and you should see the SIM slot, the rest is self explanatory. Just replace the battery and cover when done and turn on your iPhone.
Sep 16, 2009 | Apple iPhone 3G
New iPhone 3G unable to get started
Here is the iPhone 3g user guide:
http://manuals.info.apple.com/en/iPhone_User_Guide.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 20, 2009 | Apple iPhone 3G
Apple iPhone Smartphone Logo
285 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
