Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wring sensors Does anyone have a wirng diargram for the "eyes". For some unknown reason the previous owner disconnect the sensors and I am not sure how to connect the wires again. The door opener is a Craftsman 1/2 HP, model 134,18876, purchased from Sears Canada about 7 years ago. It also will only go down a few inches unles I hold the down button until the door reaches the floor.
  • marc38 Feb 09, 2009
    Clarkeo2002,
    Thanks for the info. I connected as you suggested and found out the "receiver" module does not have a green light. To make sure it was the "receiver" I switched them around and it confirmed the "receiver" green light does not come on. Any idea where I might find a replacement?
    Thanks again
  • marc38 Feb 10, 2009
    CLarko2002,
    Thanks again. I will try to find a set at a local dealer, if not I'll go to Sears Parts.
    REgards
  • 360 Answers
Whites together under 2nd screw, grays together under 3rd screw. both indicator lights (normally LED's) on the eyes (1 each) must be lit in order to operate. this is the basic set-up...if you give me your model number from the opener, I should be able to find a owners/users manual for the unit
please take the time to give this solution a fix ya rating
Thanks for using Fix Ya
clarkco
Posted on Feb 09, 2009
  • clarkco2002 Feb 10, 2009
    safety eyes are generally sold in pairs. The model # in your post does not show up in any data base I can access, including sears. Check the model # and go to searspartsdirect.com or any GDO installer in your area should be able to point you in the right direction for a local source.
Garage door reverses for not reason even with the sensors disconnected
Ugh so after a half hour of trouble shooting this issue there was a small part of a leaf stuck to the bottom of the door. Sticking out just enough to trip the sensor right at the bottom. It was intermittent. Sometimes it would trip it sometimes not.
Sep 27, 2014 | Building Materials
Mfu14f3gw2 wiring diargram
Good Morning Jon - The best way to locate a Wiring Diagram for this particular unit, MFU14F3GW2 is by visiting the manufacturer website. The Owner's Guide and Parts Manual are also available. Hope this information is helpful and if there is anything else that I can help you with, please feel free to reconnect!
Jun 09, 2013 | Frigidaire Freezers
I am using ultrasurf since 1 year in my pc 8440 but due to unknown reason it dosn't work anymore so, what will be the reason and how can fix this
Did you reload the software? Try that first, check for updates. If it was recently updated then, roll back the update to the previous version.
Apr 21, 2013 | Computers & Internet
Bmw k1100lt se radio removed by previous owner bike came with radio but many wires need to know wirng diagram to re fit
Hi, Davidpeel11 I am sorry you can't find the first and best tool you ever bought for your BMW but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
BMW 1100 LT radio wiring diagram Google Search
K1100LT 1994 On Wiring Diagrams BMW K75 K100 K1 K1100
http://www.rbracing-rsr.com/downloads/K1100LT_RS_Repair.pdf
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
K1100lt Owners Manual
Jul 13, 2011 | BMW K 1100 LT Motorcycles
Dell inspiron 1525 master password needed. system#6J391H1-595B. Service code=14215012021. In desperate need for help.
register the laptop with dell. thy will give you the code over the phone for free.you can transfer ownership even without knowing the previous owners name. simply enter "unknown" when the form asks for previous owner
Apr 23, 2011 | Computers & Internet
So, i have a Tracker that has been changed, by the previous owner, from factory auto trans to a 5 speed. It has an issue with the engine (bogs) and the gauges (go haywire), when you run/ shift into gear....
Hi, the wiring is certainly different as the automatic has shift and TCC solenoids that the manual does not have. The safety interlock is also different--on the clutch pedal for manual versus the trans range sensor on the auto. Also, the backup light switch is separate on the manual versus integrated to the range switch on the auto. The speed sensor may be different or the same, I'm not sure. Now, the real difference in the drivability is that the auto trans is controlled by the PCM, and the data is fed back to the PCM for proper engine operation. If the previous owner didn't change the computer, then the algorithms in the computer are not optimized for a maunal transmission. I'm not sure that is the reason for your problems. Can you find out if the PCM in the car is the original versus a replacement for a manual transmission?
Jan 20, 2011 | 1998 Chevrolet Tracker
I need the correct description on how to install the brake cable
Seems like the previous owner disconnected it from the push handle and now of course it is to long. Remone pull grip thread through eye bolt on the top side of your mower handle, replace pull grip...........You should be good to go. If the eye bolt is missing, you should see a hole in the mower handle toward the top where it used to be !
Sep 11, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
How to replace output speed sensor for 2001 kia optima.... i can not get the clip off... does anyone know how to replace the output speed sensor? or have a diagram of how to do it
most of the Kia connectors have a silver wire clip that must be completly removed before in can be disconnected....i use a sharp pick to pull them....just watch it dont go flying of to locations unknown
Aug 13, 2009 | 2001 Kia Optima
Wiring diagram
Do you need the owners manual diagram or the actual schematics for repair?
Jan 23, 2009 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
75 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
