Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
Windows XP will not recognize my WD 250GB Harddrive
My computer will not recognize my WD 250GB External Harddrive anymore. I plug it in the USB drive and my harddrive instantly turns on (even though I never actually turn it on). The computer still does not recognize it. It's not recognized in any of my roommates computers either and I've tried different USB cords. Does anyone know anyway of fixing this problem?
  • 1 more comment
  • djroach Feb 09, 2009
    No it doesn't. Not one that I've noticed anyway. Once I turn on the Harddrive it won't turn off without being unplugged. If it were to make a tick what would I do?
  • Anonymous Feb 22, 2009
    Same issue here. It worked on an XP machine and Vista, then nothing. Lights turn on, but not recognized by any PCs. Tried 4 computers 3 XP 1 Vista.
    Tried every combination of off/on, plug/unplug, changed wires, etc...Very frustrating. I did not backup my backup drive....
    WD needs to provide some support on this issue.
  • James Louie Puro
    James Louie Puro May 11, 2010
    does it produces a sound like tick when you plug it?
    Problem Solver:
  • 8 Answers
Just plug your USB HDD directly into your MBoard's USB port...
Posted on Feb 12, 2009
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
My WD External harddrive is not being recognized by my computer
Need more information about the problem. Your computer type and operating system and also if your hard drive came with any power source?
Sep 02, 2011 | Western Digital 250GB MyBook External USB...
WD 500G HDD suddenly un-readable; changed name to local disk, says I need to format in order to use it. I have tons of important stuff on there.
Could you confirm if the problem with the drive not being recognized is a problem with the USB cable? I have a 250GB passport and it worked fine with my XP. Once I decided to reformat it to NTFS and tried to do so by plugging into my new windows7 laptop the problems started.
Aug 21, 2011 | Western Digital My Passport Essential...
Wd drive windows not recognized
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jul 23, 2010 | Western Digital WD Passport 250GB Portable...
Computer won't recognize external hard drive anymore
Have you tried changing the USB cable or connecting it to a different USB port on the computer?
Nov 14, 2017 | Western Digital 320GB MyBook External USB...
EXTERNAL HARDRIVE NOT RECOGNIZED IN WINDOWS XP
Uninstall the driver and then reinstall. make sure the drive is not connected until the driver is installed.
May 30, 2010 | Western Digital Elements powered by WD 320...
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
May 03, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Jan 16, 2009 | Western Digital Passport WDXML800UE...
Isn't being read anymore
Please repair the master boot record(mbr) might be damage cause of viruses. If the harddrive detected in the CMOS there is no possible that can able to format the harddrive using windows utility such as XP Bootable CD or 98SE.
Hope this will be helpful to you.
Oct 25, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
1,410 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
