What we're going to do here is take all your photos and put them onto one 8 1/2 x 11 sheet of paper.
So take some tape and put it on the BACK of a photo. Then put that photo on the 8 1/2 x 11. You want to do it on the back so it won't ruin your original.
Then repeat this for the other photos you've got. And make sure you leave some space between the photos. This is so they don't get stuck together or overlap.
If you have lots and lots of photos that won't fit on one page, then use multiple pages to hold them. In other word, put as many as you can on a page.
Step 2
** Preparing to scan**
Now that you've got your photos on an 8 1/2 x 11 piece of paper, it's time to put it onto the scanner. And be careful when holding the paper so your photos don't all fall off.
Now carefully lay the paper with the photos facing DOWN on the glass of your scanner. And it doesn't matter if you're using a flatbed scanner or one of those combo printer/scanner/fax machines.
TIP #1: I suggest making sure your glass is clean and free of streaks beforehand. Otherwise, you may see lines or distortions when the photos are scanned.
TIP #2: Do NOT feed the paper through the sheet feeder if you have one. This may jam the feeder or damange your photos. So make sure you only lay the paper on the glass!
Step 3
** Ready to scan **
The only thing left to do now is actually scan your photos. Now depending on your scanner software, you may be able to scan a specific area.
In other words, many scanning software programs allow you to select the region or area of the paper you want to scan. If so, then I suggest you use this to crop your image around a specific picture. This will make the process easier.
When you've done this, scan it! Once it's on your computer, you can edit it to make it ligher, sharper, etc. Or save it as is. Then you'd repeat this process for the next picture.
If your software won't allow you to scan a specific area, then you'll need to scan the entire page. Do it! Once the image is on your computer, then you can use editing software to copy a specific portion to a new file. This is what you'll need to do to get individual photos.
As an alternative, you could crop the one you just scanned and then save it. Then rescan the whole page again and crop it to the next picture. Both ways work the same, so is your choice which way to go.
Using your scanner program such as PaperPort, you really have to pay attention on where the document/photo is located for scanning.
Steps 1. Click on Start, Programs, Paperport 2. Right above the Word "SCAN", you will have several options on; a. Document or Photo b. Flatbed or Feeder 3. Once step 2b has been selected, the M20i will scan your document per your instructions.
Note:#1 If you place your document on Flatbed but your selection on your screen says "Feeder" where do you think the scanner will look for your document? The answer is --> Feeder!!!
Note #2 Make sure that you click Accept,& DONE, other wise M20i will just sit and wait for your next command.
I hope this resolves the confusion between GLASS and FEEDER scanning.
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
If you are receiving an Error Code 103 or a Paper Jam error,
but there are no pages in the ADF (Automatic Document Feeder), follow
the steps below:
Close the scanning application (such as PaperPort)
Turn off the scanner and the computer
If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
Plug the ADF cable back in
Turn on the scanner power
Turn on the computer
Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in
the rear is connected to the scanner base. Check the flatbed to make
sure that it is clear. A page incorrectly placed on the flatbed may
interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic
Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
Open the Automatic Document Feeder cover.
Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is
running continuously, check to make sure the paper sensor arm is not
stuck down.
Look for the small black plastic arm
When you press on this arm, it should move freely up and down
If the arm is stuck down, please contact Technical Support for troubleshooting options
It sounds like the grabbing wheels in the document feeder are losing their grip. You can take alcohol to rub down and clean the rubber tires in the document feeder. There is a possibility that a very small piece of paper is jammed in the feeder as well, which can cause the paper to jam and make a weird noise. Please let me know if this resolves your issue. Thank you.
