Age of machine 7 years --- single hand handling, Well maintained. Rajesh Gupta Pune
Here you can find solution for any kind of complications occurred in your VIdeocon washing Machine.
http://aktechnoservice.com/videocon-washing-machine-service-center-in-hyderabad/
This can be due to a error in the control panel, You can switch off, remove the front panel and check for moisture on the panel, if so use a dryer to ward off the moisture. Also check the connections on the board. If the fault reoccurs then you might need to replace the panel board.Make sure the door switch, inlet valve and drains are clean.
SOURCE: My Videocon Fully automatic top
Hi
E9 means the water level sensor is
defective or the pipe connected to it is faulty.Generally error E9 means a
problem with your water pressure sensor. do you have water in the tub? Check
the sensor by pulling the hose attached to the bottom part of the tub and blow
on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have
further query else please accept the suggestion.
Thank you for contacting fixya.com
Hi
