Question about Intel Motherboard
Graphics problem where to find display driver for gigabyte 8S651M-RZ
    President:
  • 2,110 Answers
Vga comb coma
Sounds like a driver problem, try this:
http://www.gigabyte.com/products/product-page.aspx?pid=1778&dl=1#dl
And download the correct driver.
Dec 14, 2013 | Gigabyte 8S651M-RZ (GA-8S651M-RZ)...
HOW CAN DOWNLOAD VGA DRIVER OF 8S651M-RZ
You can download drivers for this motherboard here
May 04, 2012 | Gigabyte GA-8SIMLH Motherboard
Dear Sir, Gigabyte 8VM533M-RZ Motherboard shows 640x480. I can not set to 800x600 or above and permit for limited job. Is there any solution? Please help me. -----Harun
Hello sir,
From the motherboard brand you have, below are the technical specifications: Chipset: VIA ProSavageDDR P4M266A Graphics: ProSavage8 Graphics engine.
The reason you cannot set the screen resolution in Windows XP above 800*600 is because you do not have the appropriate drivers installed for your machine, i.e for the VIA ProSavage8 Graphics card. To solve this problem,you need to download and install the necessary drivers. You can download them from the link below: http://ranger.s3graphics.com/swlib/
Just accept the license agreement and browse through the FTP folders for the S3 ProSavage8 graphics driver(Alt. called ProSavageDDR).
Hope this solves your problem.
Feb 09, 2011 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Ive got gigbyte 8S651M-RZ mother board no picture
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, graphics card (if required) and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card or the motherboard. The next step is to replace each one of the first five with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a bad Board. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Good Luck,
Mark
Jan 31, 2010 | Gigabyte 8S651M-RZ (GA-8S651M-RZ)...
I want to download gigabyte 81845GVM RZ Audio Driver can anyone help me in this regrad...
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1767
8I845GVM-RZ Enlarge View
8I845GVM-RZ
AddThis Help
1. Supports 533MHz FSB Pentium® 4 Processor with HT Technology
2. Support high performance DDR333/266 memory
3. Provides 6 USB 2.0 ports for high-speed connectivity
4. Integrated new generation Intel® Extreme Graphics Engine
5. Integrated Ethernet 10/100Mb Network Connection
6. Integrated high quality 6-channel AC' 97 audio
Audio
Download Date Description Version Size
Download from ... 2006/12/19 Realtek AC97 Driver
O.S. : Windows 98,Windows Me,Windows 2000,Windows XP,Windows XP 64Bit 5.10.00.6160 30.47 MB
Jan 06, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Software
Just google it you should be able to download drivers for it. Most of the time you can download drivers for motherboards and graphics cards from gigabyte themselves
Jul 26, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
