Question about Biostar TFORCE4 U 775 Motherboard
My PC won't turn on at all anymore...
I have a TForce4 U Ver. 1.0 mobo with AMD 3200+ processor. At first, the computer would turn on for about 30 seconds and then turn off. Then all of a sudden it shut off all together. I thought the power supply was shot, so I borrowed my friend's and it turned on; however, no signal to the monitor. So I borrowed a video card (no on board video avail), but it still had no signal. I cannot figure out the solution. There is a small red light that stays on labeled D13 on the motherboard. Don't know what that would mean. I tried resetting CMOS, but does not fix the problem. Can anyone advise on what the problem would be and how to fix it? Thanks
    President:
  • 1,902 Answers
The problem is *********** board. If you can not get any signal but you are getting power to your motherboard then the board is not sending power anywhere else. Replace the motherboard and all will be ok
Posted on Feb 09, 2009
Unknown processor for NF61S MICRO AM2 SE VER 6.0
additional question, can
BIOSTAR NF61S Micro AM2
a
AMD dual core X2 7750 2.7processor? which is a am2+ socket processor.
Sep 15, 2012 | Biostar NF61S MICRO AM2 SE...
Tip
How to Remove a AMD Processor
<p>Removing a processor AMD is a work that can only be done with a screwdriver in less than 30 minutes. The processor AMD is a central processing unit (CPU) with 939 pins, which are connected to the motherboard. Removing the processor is an issue to withdraw from the motherboard with your hands after you remove the heatsink from the chip.<br /> <p> <br /> <p>1. Turn off the computer and unplug the power cord before removing the AMD processor. Unplug the connector on the back of the computer case and remove the screws, the lid of the computer, in the case with a screwdriver.<br /> <p><br /> <p>2. Slide the computer cover and set aside. Pull the cord that connects the heatsink fan on the motherboard with one hand.<br /> <p><br /> <p>3. Lift the lever on both sides of the fan heatsink, so straight up and remove the plastic clips on the sides of the sink on the motherboard.<br /> <p><br /> <p>4. Pull the heatsink and fan on the motherboard and set it aside.<br /> <p><br /> <p>5. Lift the AMD processor motherboard and carefully remove it from the computer.<br />
on Jun 21, 2011 | Computers & Internet
What motherboard is in the compaq presario with amd 3200 sempron processor
the mother board in the compaq presario 3200 is a MSI N1996 and for the drivers you go to this web site Compaq .com/support that is where you can down load the drivers for your computer free of charge.you might be able to buy the disks that you need for recovery,restoreand proble some other ones
Dec 29, 2010 | AMD Sempron 3200+, 1.8 GHz (SDA3200CNBOX)...
THE Driver of MS:7312 VER:1.0 VIA Mother
go to the amd website and you can find the drivers there
Feb 15, 2010 | AMD Sempron 3000+, 1.6 Ghz (SDA3000AIO2BA)...
I have no audio on my pc, ms-7309 ver:1.0 model
Plz check audio driver is installed or not and visit the link given below and download Fix Driver Detective.http://www.topshareware.com/Fix-Driver-Detective-download-71919.htm
or
search audio driver on
http://www.topshareware.com/downloads.aspx?q=ms-7309-drivers-ver-1.0&p=1
plz rate me if it heips to you
Feb 04, 2010 | eMachines D3123 Desktop Computer With AMD...
Cpu update
basing from MSI website cpu support for this mobo,
the best AMD processor you can fit on this mobo is
ATHLONXP 3200+.
Barton (0.13u) 200/400MHz FSB 512KB L2 Cache AthlonXP 3000+ 200 Auto OK AthlonXP 3200+ 200 Auto OK
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=592&maincat_no=1#menu
Oct 13, 2008 | Intel Motherboard
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
Computers & Internet Logo
100 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
