Question about Microsoft Xbox 360 Console
2 flashing red rings
Hey,
I sent my xbox in for repairs for two red rings to fix. i just got it back 3 days ago and now im getting the same problem two red rings.
It sounds like your console is overheating, but it's hard to be sure without more info. Which of the four lights are flashing?
If you keep it in a cabinet, try moving it. Make sure it's not sitting on carpet and that none of the vents/fans are blocked. You might want to look into an aftermarket snap-on set of fans.
You can get more info about 360 error codes / diagnostics here:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Posted on Feb 09, 2009
If theres two red lights all that means is that its overheating. unplug all ur cables and put it underneath ur bed for an hour, then plug everything back in and keep playing
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
The Xbox power button is flashing a red colour around it when turned on
You have what is commonly known as the "Red Ring of Death" There are a few different types of rings (denoted by which actual quadrants of the ring are lit), the most common one can TRULY only be fixed by an experienced tech. You should eject any discs, turn it off, eject the hard drive, take out any other storage devices, unplug all cables from the unit, and mail it to Microsoft for repair. Hopefully it is still under warranty. I got a refurbished unit sent back to me just a week after I sent my own off to them when this happened to me a couple years ago, I had a custom face plate on mine so I had to remove that as well when I sent it in because I was not guaranteed to get my actual unit back.
Nov 01, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: red ring of death...
if you have one, two, or three rings, give the xbox a lot of time to cool down. If you have four, your xbox is fried.
May 18, 2010 | Microsoft Xbox 360 Console
Red rings of death
  1. I had this problem with my Xbox 360 with the three red rings. I did a Google search and found alot of the fix it yourself websites. I tried it and not only was I not able to fix it I made the problem worse. So then I started looking for repair places. I came across www.videogame911.com. I filled out their online order form and sent my XBOX repair off. Within days of shipping it out I had my system back. They were very quick and affordable and they provide a warranty. I've had my system back for over 3 months now. I play it for at least 3 hours a night and I have had absolutely no problems with it. I would highly recommend them if your looking to have your video gamesystem repaired.
May 15, 2010 | Microsoft Xbox 360 Console
THREE RED LIGHTS
just got mine fixed call1-800-469-9269 took one week to get it back one of the first xbox 360 to come out . red death ring is because it over heated .didnt cost me anythang they even sent me the boxes to ship it in
May 16, 2009 | Microsoft Xbox 360 Console
3 flashing red lights
Im sorry to hear and tell you this...
You must know that that is a issue called the Red Ring of Death and is only fixed getting it sent into Microsoft. If it is no more than 2 to 3 years old you will be able to have it fixed for free.
Dec 18, 2008 | Microsoft Xbox 360 Console
Red ring 3 of them
What you are experiencing is known as the Red Ring of Death. You 360 has malfunctioned for one reason or another and no longer works. You can call 1-800-4-MY-XBOX (1-800-469-9269) or go to the support page listed at the bottom and click "repair my console" and they will repair it for free. The only downside is that you will have to wait a couple weeks (usually no more than two) for it to come back. Everything is paid for by Microsoft, including shipping. Sorry about your inconvenience.
http://support.xbox.com/support/en/us/xbox360/default.aspx
Nov 15, 2008 | Microsoft Xbox 360 Console
Fix xbox 360
red ring of death
MS have a repair or replace recall for this failure, contact MS to begin the process
Jul 11, 2008 | Microsoft Xbox 360 Console
Ring of Death
3 red lights or 4? a xclamp repair usually takes care of 3 red lights or u can send it msoft
Jun 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
141 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
