Question about Kenmore Elite 45986 Front Load Washer
Tub won't fill with water
My Elite Washer all of a sudden after two years will not fill with water. I put the lid down and the aggitator starts to go with no water in the tub
  • dawn_soviero Feb 09, 2009
    My Kenmore Elite is a top loading machine that the water will not flow into. When the lid is put down the aggitator starts with no water in the tub.
  • 1,902 Answers
You have a bad inlet valve. The valve is behind the hoses, you cant get to it one of two ways. Either through the top by removing the knobs and screws and face plate. or by removing the panel behind the hose
Posted on Feb 09, 2009
Washer fills with water but will not drain and the aggitator is not moving either. Could the problem be a bad or stuck aggitator?
When the machine is ready to drain get the hose in the back and put it down either out the window or in the tub what ever is closer and the water runs out on its own
Aug 06, 2011 | Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
I have a GE topload washer, I think the model # is WBSP1060T( there were three model # on the washer-VVSRV1040V & YVSR1040V were on there too) any way the water will not stop filling no matter what...
as to the filling issue this would either be the pressure switch or the hose that goes to the pressure switch to the tub has come off if you have any further questions message me back and please remember to rank this opinion it allows me to help others in similar situations Thanks Rick
p.s the starts agititating is normal when the lid closes it is engaging the lid switch
Mar 14, 2011 | GE WBSR3140D Top Load Washer
The machine fills and will not start agitating unless the lid is open and closed several times.
The most likely failure is the water level pressure switch or a failed lid switch. If the washer will drain and spin then it's not a failed lid switch. If it will not drain and spin the likely failure is the lid switch.
The water level switch (pressure switch) has 3 wires attached to it, V (violet), P (Pink) and a T (tan) wire. When the tub is empty of water, contact V&P are closed to allow the tub to fill with water. Once the water level reaches the desired setting, contact V&P opens and then contact V&T closes to start the motor agitating. So, with this said if you were to unplug the washer and remove the wires from the water level pressure switch and test to see if terminals V&T is closing by using an ohm meter would indicate if the contact is closed or not.
Jan 12, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
GE washer wont drain or spin, lid switch has been replaced and so has the timer. At the start of cycle it fills and aggitates properly.
If the machine tries to spin for a few seconds and shuts down because the tub is full of water, then - The first thing I would do is check the pump. You may have something blocking the pump or the pump could have failed. Newer models built within the last 10 - 15 years must drain their water down first before they are able to spin.
Jul 28, 2010 | GE Washing Machines
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't aggitate or spin.
your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Feb 01, 2009 | Whirlpool LSR5132PQ Top Load Washer
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Jan 18, 2009 | Kenmore 20722
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
55 people viewed this question
Sal De
 Brian Main
Brian Main
