Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Sometimes Pc restarts
sometimes pc has been restarted and below error code is generated so can u guide how do i solve the same probs.
Error code 00000024, parameter1 001902fe, parameter2 ba4dba94, parameter3 ba4db790, parameter4 8052c166.
your's faithfully
~Kaushal
    President:
  • 1,902 Answers
Typically due to a bad driver, or faulty or incompatible 3rd party hardware or software
1. when & how did this problem start?
2. Did you try adding any new third party hardware or software
(This could be anything a PCI card, a new video driver, windows update, a 3rd party wireless card
3. Try a System Restore
4. Remove all PCI cards, uninstall all 3rd party H/W and S/W
5. Try reinstalling all the drivers in the right order
6. Run diags on Memory
7. Repair the os
8. If all these fails, you could suspected memory
Posted on Feb 09, 2009
How do I correct the problem code C 0000001 on Windows 8 operating system
Solve Error Code 0xc0000001 in Winodws 8 Team Windows 8
Windows 8 Blue Screen of Death (BSOD) or Error Code: 0xc0000001 sometime occurs without any specific issue. You can't be sure what actually caused it. Be it a system issue or some driver problem, you may end up seeing this screen when you restart your computer.
To solve this blue screen error in windows 8, turn off your computer and when you power it up again, immediately press SHIFT + F8 key you will be resented with following screen:
Click on "See advanced repair options" and from the next screen, choose "Troubleshoot":
On the next screen, choose "Advanced Options"
In Advanced Options, choose "Windows Startup Settings"
There you will find a button "Restart". Click on this button and allow the wizard to complete all the steps. Note that it will repair your computer without making any changes to it. Once the process is completed, your computer will automatically restart and you should be able to boot windows now.
Still facing same error?
If you have followed all the above mentioned steps but got no luck in booting up your windows then probably your cause of the error is more solid and cannot be restored with mere settings reset. But don't worry, it can still be solved using windows recovery options. For this you should have a recovery/installation disc or USB Flash Drive.
Windows 8 Recovery Guide Recover When Windows 8 Fails to Boot Team Windows...
Jul 07, 2015 | Computers & Internet
Dns probe finished no internet
Issue is with your internet connection or network adapter. Suggest you follow the steps listed below to fix this BEST FIX DNS PROBE FINISHED NO INTERNET
Mar 11, 2014 | SVP NEW
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
Sometimes,,when I open my pc,,there is a blue screen appeared after the windows xp logo and it restarts again after a few seconds..you cannot read the error because it restart fast
Follow the steps below to capture the blue screen error code.
1. Turn the computer on.
2. Keep tapping F8.
3. On the Advance Boot Menu, use the arrow keys to select Disable Automatic Restart on System Failure.
4. Press Enter.
The next time that the blue screen shows up, it will be paused and you can get the error code. Let us know what type of error code you are getting and we will be more than happy to help you out.
Thank you for visiting FixYa!
Apr 25, 2011 | Computers & Internet
6 beep codes on startup
A20 ERROR- KEYBOARD CONTROLLER
Mar 26, 2011 | Dell Dimension 1100 PC Desktop
I keep getting an error mess of 0xc0000225 when turning on my laptlop
We would like to know the exact error message or error code you receiving. Follow the below steps to get error message.
i. Restart the computer
ii. Start tapping F8 key
iii. You will see advanced boot option window
iv. Select " Disable automatic restart at system crash"
You may even check for the boot sequence order in BIOS.
BIOS DISCLAIMER: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
Mar 24, 2011 | Computers & Internet
Starting problem, sometimes automatically restarts or shutdown
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
Check for PSA Error codes on support.dell.com.
If all Test Passed. Then Perform Dell Factory restore or OSRI.
Jan 16, 2010 | Dell OptiPlex GX280 PC Desktop
To solve code error 0146 and 0148
Hi there.
0146 error is DST Log contains previous error(s).
0148 error is
IDE ERROR: status (x) (s)
This could be a problem with the BIOS, restart the PC and hit F2 as it starts up, this will take you into the bios, reset the bios to default setting, press F10, save and exit the bios, the PC will restart so perform another check and see if the same error code return.
Good luck
May 29, 2009 | Dell Inspiron 6400 Notebook
Sometimes pc restarts
may have been a filesystem problem...do one thing. if you have the winxp cd..boot in recovery console.
refer here for info on how to run reconvery console.
in the console command, type chkdsk /r, like this
c:WINNTchkdsk /r
let it run until finish...do this several times, at least 2 or 3 times. then restart your PC again.
if you don't have the winxp CD, but still can go to windows. try running the check disk using command line.
START >> RUN >> type cmd
in the command console type chkdsk /r then press Y......restart your PC.
let us know if you need more info.
Feb 09, 2009 | Microsoft Windows XP Professional
Computer Restarts.
Most probably windows is generating an error and your computer is set to automatically restart when an error occurs. Try disabling automatic restart. right click my computer and select properties. click on the advanced tab and uncheck the automatically restart check box.
The reason why we need to do this is for us to see the actual error so that we will know what to do.
Oct 08, 2008 | E-Machines eMachines Desktop PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
106 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
