Question about Sony Computers & Internet
Replacing a fan on a Sony PCG-6G4L notebook
I need help replacing a fan on a Sony PCG-6G4L notebook. I've taken all the screws necessary to see the fan but I am stumped on how to replace my fan with a new one.
Any suggestions on how this is done will be appreciated.
Access to a service manual for this model would be great.
Thank you for looking.
  • 66 Answers
You can download manuals, etc. at http://esupport.sony.com/ You can also order parts from there. There are several models listed for the PCG-6G4L that you specify, so I can't be as specific as I'd like to be, but you will be able to find it easily and put your new fan in :-)
Posted on Feb 11, 2009
Screen brightness
I would try getting a firmware update for the system, if that does not work the motherboard maybe the issue. It might be time to replace the laptop.
Good Luck.
Apr 20, 2014 | Sony Vaio Pcg-6g4l 13.3" Laptop Computer...
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
Download driver sony vaio pcg 6g4l
there are normaly 2 codes found on Vaio's, do a look up on the other one.
Aug 27, 2013 | Computers & Internet
Follow the following link to download the driver. You must know you model number before opening this site.
http://esupport.sony.com/US/p/select-system.pl?model_type_group_id=10#
Done.
Aug 02, 2013 | Computers & Internet
Loud vibrating fan
This could be a fan with worn or loose bearing, could also have loose mounting screws. Check the fan and heatsink assembly, mounting screws, replace the fan if necessary and clean and remove the dust from the heatsink and vents.
Aug 15, 2009 | Sony Laptop Keyboard 1-477-006-21 for VAIO...
Replace DVD Drive in a Sony Vaio PCG-K23
Here is the service manual for your unit with an exploded view of the notebook. Post back here if the guide still help you solve your problem.
Feb 25, 2009 | Sony VAIO PCG-K23 Notebook
How do I access the inside of my VAIO PCG-K27 notebook to clean i
This issue will be resolved by replacing the fan in your pc. Go to radio shack or your local computer store for replacement.
Jan 05, 2009 | Sony VAIO PCG-K27 Notebook
Sony pcg-k35 cleaning
I had to figure this out not long ago.
First you need to pry up the piece of plastic trim that covers the speakers at the top of the keyboard.
Next romove the screws that hold in the keyboard. they will all be along the top of the keyboard.
Once that is out of the way. Remove the screws that secure the metal sheild plate and remove the plate.
You can now see the two fans. If you follow the air ducting from the fans there will be some peices of a tape like material that once pulled back will give you access to the airway to the cooling fins. This is were you will use compressed air to blow out dust build up.
It is also a good idea to clean the fan blades.
Once this done, replace the tape covers and reassemble.
I hope this helps because I couldnt find any info on this on the web.
Apr 01, 2008 | Sony VAIO PCG-K35 Notebook
Computers & Internet Logo
2,108 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
