Question about LG Shine KE970 Cellular Phone
The clothings have a kind of 'acidic" smells after being dried.
LG CONDENSER DRYER : TD-C70040E.
I just bought and used this dryer for 2 days.
Another question: Is this type of Condenser Dryer supposed to give out " hot air " just like ordinary tumbler dryer ?
Thank you.
  • alftra Feb 10, 2009
    Hello Guru,
    It is LG Condenser Dryer TD-C70040E
    thank you.
    Hello Guru,
    thank you.
    Genius:
  • 1,011 Answers
Sir,
is a condenser dryer that does not need to be ducted out with a venting kit. Installation is simple and easy as you do not have to employ a handyman to put large holes in your lanudry.
LG condenser dryers heats up the drum, evaporating the moisture from the clothes. This moist air passes through a condenser which cools it down into water. This water can then be collected in the water container and used or pumped down the drain pipe.
Quick and efficient cycles that cater for most fabrics and loads needed. The facility to enable the condensed water to be discharged automatically through an ordinary u-trap available in most utility rooms nowadays, is a big advantage.
Thanks Good Luck
Posted on Feb 10, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..ya it has two types of options.one is it
sends out the hot air and the other option
is that it comes out with the cold air.Two
types of drying options available in your
model.The smell wat you get is not related
to your dryer in any way,that is the detergent
soap wat you use for washing the clothes.
check this out..
thank u..
  • Hariharanath V Feb 10, 2009
    hi..u don't have any type of problem with your Lg
    condenser dryer.
    check this out..
    thanks..
    President:
  • 1,902 Answers
What is it that you have? A LG cell phone or a LG dryer?
LG TD-C70040E Automatic Clothes Dryer. The diver closes the cover and forces it to work and makes noises
call a good repair service locally,perhaps they will understand what you say
Apr 21, 2018 | LG Dryers
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
My condenser tray is not filling up with water but the dryer is still working. where is ther water going and why do my clothes smell ?
I have the same problem, my water is gathering behind the condenser unit but it's stopped drying the clothes aargh!!
Jul 12, 2009 | Hotpoint TDC32 Electric Dryer
Clothes come our smelling bad
Run a load empty on the hottest setting with a cup of bleach.
Then, after finished using the machine each day, leave the door open for a few hours to allow the rubber seal to dry.
Jun 30, 2009 | Zanussi FLA1001W Front Load Washer
LG TD-C70040E dryer shows ELE/EHE code ....
This happened to my LG dryer and I took of the raised back panel that covers the flywheel and there is a red reset button. This worked for me.
Good luck
Funny how this happened after 3 years exactly. hmmm
Jun 14, 2009 | LG DLE5977 Electric Dryer
LG TD C70045E problem
Fluff has blocked the drain hole into the water drawer.Try locating the hole and using a small bore plastic tube **** the debris out of the container.
Feb 21, 2009 | Zanussi TC7102W Electric Dryer
Oily smell on my clothes from the dryer
have you tried tide with fabrezze?
Feb 19, 2009 | GE DBXR463GB Gas Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
LG td-c70040e tumble dryer Clean Filter indicator will not go off
There is an access flap below the door on the bottom left.  Open the flap turn blue levers, take plastic cover off (there may be a bit of water there).  Clean the inside.  Problem solved
Nov 08, 2008 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
116 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
