Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Changing channels on its own.
This may seem alittle freaky, but w have two dvrs in our house and the downstairs one works fine, but the upstairs has some werid problems. no one can be upstairs all day and the dvr lights for upstairs will be on. there also have been times where you could be watching a show and the remote is not near, and it will start changing channels on its own. i am not really sure what is going on here,but if anyone has any idea of what to do please let me know, thanks.
  • 374 Answers
Provided the receiver is in dual mode than the problem lies in the remote address for your TV2 remote. Take the TV2 remote to the TV1 location associated with that system. With the TV1 remote and TV on press menu menu on the TV1 remote this will bring you to the System Info Screen. Near the bottom of the screen there will be two remote addresses- primary=TV1 and Secondary=TV2. Make note of these and go to the other dvr receiver you have and do the sam as you did before. It is important that the address for the secondary remote at the first location and the remote address for the secondary at this location if on a duo receiver are not the same. Now go back to the TV1 location you were oiginally at and using the TV2 remote press and hold the small clear SAT button until all light across the top light up. Now key in a two digit number that is different from the original secondary address at this location and also different than the address at the other location. Now press the pound key and the SAT button will flash thrice. Now press the record button a few times until the secondary address changes to the number you selected. Once this is doone you can exit out of all screens on all receivers and go to the TV2 location that was having the issue and it should be resolved. More than likely either a neighbor had their remote address the same as yours if they are within a 100 feet or the remote address defaulted to the same as the other dvr. I hope this helps you and thanks for using Fix Ya. If you need further assistance please let me know.
Posted on Feb 11, 2009
I have a foxstat -HDR humax box and I am getting no or bad signal on the TV downstairs. I can get some channels but not all.
I suspect that the box upstairs is a Freesat box; a Freeview box requires a feed from an aerial, not a dish.
The problem you are seeing may be caused by water in the cables, if they are not sealed at the LNB. The LNB may be failing, but dish misalignment is more likely.
As there is an unused output on the LNB, try swapping one of the feeds with a poor signal to it.
Jul 27, 2015 | Humax Televison & Video
We just dvrs hooked up a few weeks ago.when I am recording somthing down and my daughter goes upstairs to watch her tv and tries to change her channel to watch somthing a message comes up on the tv that...
Hi, poog_23350, I caught your post! How a Duo DVR receiver works is that the TV you have it set to record on will not allow you to change the channel while the recording is in progress. The other TV, that isn't recording anything, can be used freely to flip through channels.
In this case, it's TV2, the one upstairs in your daughter's room, that's currently set to record on while the downstairs TV is free to use. This can be adjusted by pulling up the Main Menu with the Menu button on the remote, selecting option 8, then option 5, and changing the TV1/TV2 setting there on the Record Plus screen.
If you'd like a receiver capable of allowing channel changing while recording a program, our VIP 612 receiver is a Solo receiver that acts like a Duo. What this means is that it has one TV output and two tuners. Along with being able to change channels while a recording is in progress with this type of receiver, you can also record two programs on two different channels simultaneously.
Hope that helps!
Aug 29, 2011 | DISH Network DVR-625 DTV Receiver /...
Not enough heat
Take an Amp draw on all heaters and compare. If within 5%, they are working fine but you may have more open area downstairs than up.
Mar 03, 2010 | Heating & Cooling
Nikkai 2727 Video sender will not send signals from my sky+ box. The scart lead is plugged into the Video out, but even when i plug it into the TV out it still doesnt work. I know the Transmitter and...
check that you have the sender plugged into the sky box and the receiver into the required tv and not the other way round. The wrong way round still allows the controller to change channels but you will see nothing also ensure that both sender and reciever are on same channel 1 to 4
Jan 24, 2010 | Panasonic Televison & Video
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
AC unit seems to be working normally but not cooling house
If you are referring to the secondary pan there could be a problem with your drain line.i would find the drain at the exterior of your home and **** it out with a wet vac..most A.H.Us have float switches or moisture sensors.They will shut down the unit if the drain clogs.
Jun 21, 2009 | Weather King 10AJA3601AH Air Conditioner
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
Wireless router signal
I suggest that you move the router around to find the strongest signal for you computer or if your computer has a small antennae try moving that fround for the best signal
Lou Margolis
Allied Electronics
Aug 14, 2008 | NetGear WGR614 Wireless Router
Sky upstairs
Yes on the back of the box there is a RF2 output...
run a coaxil aerial cable from there to your required TV, you then need to tune the 2nd tv to the sky box.
You can also buy a 'Magic Eye' and a 'extra remote' this will allow you to change channels from the second destination with only 1 digi box.
Down point is that you have to watch the same channel on both tv's.
a second card and box and a dual LNB will allow you to watch seperate channels.
Jul 20, 2008 | Televison & Video
Signal Problems
try to bring another laptop to the location where you are having problem and see if the other laptop will have the same problem. if thats the case the problem is with the router. You can try upgrading the router's firmware or change the wireless channel
Apr 21, 2008 | NetGear WGR614 Wireless Router
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
154 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
