Question about Kenwood HM-333-S Shelf System
CD not recognized.
Say's "no disc" when one is inserted
    Genius:
  • Kenwood Master
  • 1,667 Answers
A common cause is that the laser lens has some dirt or dust on it. I have seen lasers fail causing your described fault. It is rare, but there may be a mechanical alighment problem.
Jerry G.
Posted on Feb 09, 2009
After copying the dvd video content, and inserting the blank disc, Roxio does not recognize the blank disc and continues to say 'please insert blank disc' I have tried both DVD R and DVD WR. Please help!
If your roxio software does not read or recognize the disc that you are using, you can use other brands of disc to check if the disc that you are using is not compatible with the software.
Cheers . . .
Mar 08, 2011 | Roxio Easy CD & DVD Creator 6...
I have a Dell. My Roxio prog doesn't recognize a discs
That means there is something wrong with your driver. If it cannot read any disc you inserted then the problem exist in your drive. You don't need to reinstall any driver as long as you can see your drive being recognized by your computer and you can see your drive in the My Computer with a letter indicated on it. Your drive is in need for a replacement. This problem indicates a hardware failure specifically the lens of the device.
Hope this helps..
Mar 29, 2010 | Acer (4432A-002) CD-RW Burner
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
HP PAVILION a6000n with lightscribe supermulti drive / cd writer---windows vista :: does not recognize dvd disc when inserted
If it fails to recognize and CD or DVD that's inserted you will need to reinstall the driver for your LightScribe. The factory drivers for your system can be found here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3548643
If it fails to recognize just one CD or DVD, chances are that the disc is defective.
Dec 02, 2009 | Cars & Trucks
My cd-dvd drive does not recognize discs, so movie discs are not played when I use Win Media player. I insert a disc and there is no automatic recognition of inserted disc.
You should clean your CD-Drive lens with Disk cleaner Cd that will work or move anticlock wise and your problem will be solve after cleaning the lens.
Good Luck
Nov 30, 2009 | Fujitsu Siemens LifeBook® S7110 PC...
Model #GWA-4164B DVD Writer does not recognize any disc Cd or DVD. computer sees the drive when you install a DVD it tries to read and fails . Try to explore it indicates please insert a disc. Firmware is...
It sounds as if the disc drive laser has died, when they burn out they will not recognize any disc inserted. fortunatly a replacement drive is relativly inexpensive to replace.
Aug 24, 2009 | Hitachi Computers & Internet
HP Pavillion a712n Desktop PC-CD writable drive space all used up; and it wont recognize blank CD
have not fixed it. Can you fix the title ? I sokld the pontiac. This is about an HP PC. thanks
May 28, 2009 | 1989 Pontiac Grand Prix
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
CD DRIVE - NOT RECOGNIZED
If you are having a problem with one particular cd.... examine it for scratches or smudges.
Robert
Sep 05, 2008 | Pioneer DVR-107D DVD±RW Burner
Kenwood HM-333-S Shelf System Logo
153 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Eddie Dalton
Eddie Dalton
Level 1 Expert
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
