I've installed an Adaptec SATA 2410sa controller. It presents itself as a SCSI controller to the computer.
From the BIOS I see no way to boot from this controller... it can only boot from the IDE drive.
After booting Windows XP see the new controller and it's drive correctly... but I can't set the BIOS to boot from it... the disks are Maxtor 120GB SATA connected on the SATA controller... the controller shows this as one drive (the RAID is hardward by the controller).
Anyone with a solution?
System information: Board model Genuine Intel(R) D850GB system board OS version Windows* XP version 5.1 Service Pack 1 build 2600 OS memory 523,564 KB RAM Physical memory 512 MB RAM Memory speed PC800 Memory type Other, RAMBUS Form factor RIMM BIOS date 08/20/2001 BIOS size 512 KB BIOS version P13 (GB85010A.15A.0046.P13.0108201551)
I'ts ok. P13 is fine. And is the latest one avail from Gateway (the Intel aobve P13 won't load because of the signature string in the BIOS).
It's booting from the SATA 2400sa controller now... Ah!!! My partition mover forgot to set the partion "Active" on the disk connected to the SATA controller... Simply have to set the Boot Device in the bios to diskette and nothing else, it then goes to the Sata Raid controller (showing as SCSI).
Sorry... S ...
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Intel D850GB board Boot Problem:
Solution #2
posted on Aug 01, 2007
Gary10 - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
I have the same motherboard, I went to a p4 2.5 from a 1.6 and also installed a 300GB drive. I had to update the bios, from P13 to P18. I downloaded it off the INTEL website. ...
Solution #3
Cato - usenet poster
I have the same board and I just did a upgrade to a 300GB drive which came with a Maxtor/Promise controller card. I also recently formatted my OS HD and had a problem installing XP, so I ended up pulling the card and once I got XP and updates installed it took the card ok. Though I do not have it as the bootable I have my secondary 300 and 120 HD running off the controller card.
Operating System System Model Windows XP Professional, Service Pack 1 Gateway E-4600 4000762 Processor a Main Circuit Board 1900 megahertz Intel Pentium 4 8 kilobyte primary memory cache 256 kilobyte secondary memory cache Board: Intel Corporation D850GB AAA49507-904 Bus Clock: 100 megahertz BIOS: Intel Corp. GB85010A.15A.0046.P13.0108201551 08/20/2001 Drives Memory Modules 501.94 Gigabytes Usable Hard Drive Capacity 374.99 Gigabytes Hard Drive Free Space TDK CDRW5200B [CD-ROM drive] TDK DVDRW840G [CD-ROM drive] 3.5" format removeable media [Floppy drive] Maxtor 4A300J0 (137.44 GB) [Hard drive] -- drive 1 Maxtor 6Y080L0 (81.96 GB) [Hard drive] -- drive 0 WDC WD1200BB-50CAA1 (120.03 GB) [Hard drive] -- drive 2 512 Megabytes Installed Memory 128 Megabyte Module Size - 4 Installed Local Drive Volumes c: (on drive 0) 81.95 GB 70.24 GB free d: (on drive 1) 299.99 GB 284.79 GB free j: (on drive 2) 120.00 GB 19.95 GB free
Controllers Printers Intel(r) 82801BA Bus Master IDE Controller Primary IDE Channel [Controller] Secondary IDE Channel [Controller] WinXP Promise Ultra133 TX2 (tm) IDE Controller hp officejet k series on DOT4_001 hp officejet k series fax on DOT4_001
Solution #4
Putty - usenet poster
Ron
Solution #5
Chandler - usenet poster
The D850GB may be one of those boards with limited boot options, or it simply may not recognize an SATA controller as bootable. SATA is newer than the D850GB. The BIOS in most Intel-made boards enables one to establish the boot order, and, if I recall properly, detects an external controller (e.g. Promise ATA or Adaptec SCSI) to place in the boot order. Other motherboard manufacturers, e.g. Asus, may give more flexibility in the selection of boot devices thru the BIOS.
If the BIOS does not find the external drives and place them in the boot order, as a rule, IDE/ATA drives take precedence in boot order over SCSI drives. My guess is that SATA is treated the same as SCSI.
The bottom line is that to boot from SATA you'll either need to remove the IDE/ATA drives from the system or attach them also to a secondary controller.
... Ben Myers
