Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire filter problem..
I just recently replaced my air filter for my fridge, and it's still the little air filter light is still RED. It's been a week now since I've changed it. I don't know why it's not changing back to green.
Is anyone else having this problem???
  • cecil866 Feb 09, 2009
    Holy cow, Joe. Thanks a lot!
    -C
  • ngallo Feb 19, 2009
    I have reset the filter light but it still turns back to red despite having a new filter 2 weeks ago. After you reset it, it will stay green for about 5 minutes and then return to red. Any suggestions??
  • 10,865 Answers
After changing the filter it is necessary to reset the filter status light. Press the filter status reset button for 3 to 15 seconds until the green light flashes.
If you want to look at the entire service manual you can access it at : http://www.fixya.com/support/p61551-frigidaire_frs26r4a_side_by_side/manual-4115/page-14
Posted on Feb 09, 2009
  • Joe Hogan Feb 10, 2009
    wonderful!
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
I just installed the water filter in the fridge but the light on the front door panel still shows red
This is another one for the user manual! Always check it first. It would seem likely that the system is either time or water flow controlled. By this I mean that somehow your little red light is caused to light up. For example by a little device which can measure how much water you've used. This device could need resetting.
Try contacting manufacturer
May 06, 2015 | Jenn-Air JCD2295HES Side by Side...
Frigidaire elite, red alarm light on,freezer defrosted, fridge icing up
Sounds like your heater is either out or the connectors are loose causing it not to be able to cool properly from ice build up
May 08, 2014 | Frigidaire Refrigerators
The water stopped coming out of the water dispenser and the ice maker will not make and drop ice. The line from the house to the fridge is not clogged, the lines to the icemaker do not appear clogged.
Sounds like someone accidentally locked you out. If you see a RED light lit above the touch pad.
To Lock Out Press the LOCK Touch Pad for 3-5 seconds. A Red light will appear above
the Touch Pad.
To Unlock
Press the LOCK Touch Pad for 3-5 seconds until the Red light above the
Touch Pad goes out.
Other possibilities:
Household water line valve is not open. -open valve
Freezer door is not closed-Close door tight
Ice & water filter cartridge is clogged-replace filter
Front filter not fully installed, if equipped-Push filter until you hear a CLICK. filter should be FLUSH with cabinet
Here is a link to the user manual.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241572801en.pdf
Hope this helps
Thanks
Please rate FIXYA
May 26, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Can't reset the filter status lights.
Is it possible you put the filter in backwards?
Mar 10, 2009 | 3M Filtrete FAP02 Air Purifier
Fridge Filter
the filter islocated behind the toe grille, ordering instructions areprinted on the filter itself, and resetting the light is a matter of holdingin the button for 3-5 secs, its filtering your water and ice
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water Filter Red Light
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Jan 12, 2009 | Jenn-Air JCD2290HES Side by Side...
Filter light has turned red
If there is a circle in the grill at the bottom of the fridge it will be there.
Dec 21, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Jenn-Air "replace filter" light
each dispensor is a little different, but youll need to hold down a button(perhaps even a combonation of 2) for3 seconds to "reset " the filter indicator.
Mar 19, 2008 | Jenn-Air JSD2789GEW Side by Side...
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
Frigidaire FRS26R4A Side by Side Refrigerator Logo
355 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
