Question about Microsoft Xbox 360 Console
Flashing Green Light
While my xbox 360 is turned off the middle light on the power button flashes green, what is wrong?
Your xbox might be downloading a game that you ask to download or some other type of media. to chick turn it on and go to active downloads and see.
Posted on Feb 09, 2009
My XBOX 360 will not turn on. The power bar has a green light but pressing the eject button or power button on the console will not turn it on. We have tried plugging it in to a different outlet but that...
Hi christoph52893,
If the Xbox 360 power supply light is green, this means the Xbox 360 power supply is ok and it is an issue with the console itself. You will need to contact Xbox 360 customer support to service your console. However, if you have a flashing orange or yellow light, it means that your console is fine but instead there is something wrong with your power supply. It indicates that it's not getting enough power.
Hope it helps.
Thank you for using FixYa.
Jul 05, 2011 | Microsoft Xbox 360 Console
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the...
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
Mar 05, 2011 | Microsoft Xbox 360 Console
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Power supply light keeps flashing green and problems with tray op
under normal conditios power supply light should be a steady green light not flashing if not power supply is might be bad call (800) 4MY-XBOX
Oct 11, 2009 | Microsoft Xbox 360 Console
Green light flashing on controller no light on 360
You need to reconnect your controller to your xbox. Next to the two memory slots on the front of your xbox, there should be a small round button. Turn on both your controller and your xbox. Push the little round button. There should be a similar button on your controller. Push that too. They should recognize each other.
Jun 27, 2009 | Microsoft Xbox 360 Controller
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
192 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
