Question about Gateway (ATX93-9405) (ATX939405) Power Supply
I have an ATX93-3405
When i turn on the power all it says is, (turn off power and reinstall the jumper in normal mode position). I took out the jumper and replaced it on 1&2 like someone else told me and i reset the time and date but it is still doing the same thing! please help me!!!!
Thanks Mary H.
  • DEKR
    DEKR May 11, 2010
    what were you doin when this error began to happen
  • 106 Answers
Try to change your CMOS battery.. ^^
Posted on Feb 09, 2009
When i start my computer boot screen appears every time.
may be you cmos battery is weak just remove the battery and install new battery and also make sure jumper position is proper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 26, 2010 | Intel D945GCCR Motherboard
Turn off power and reinstall the jumper in normal mode position
You have installed the jumpers in incorrect way,please install with correct way.Keep one piece of jumper in certain chips to set down on mother board.
So keep so care with installing it.
Nov 18, 2009 | Intel DG31PR Motherboard
i get jumper the error massage is " Turn off power and reinstall the jumper in normal mode position
Sep 10, 2009 | Intel D945GCCR Motherboard
Turn off power and reinstall the jumper in normal mode position in intal(lga775)
if this message is appearing on your screen then the bios jumper is installed at reset position. so please install this bios jumper of your motherboard and the pin number 1-2 position of bios.
it will be allright
Apr 19, 2009 | Intel Biostar P4M800-M7A Socket LGA 775...
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Feb 27, 2009 | Intel D945GCL Motherboard
If I understand what you are asking: The computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position. It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try. Will probably work for you.
Feb 11, 2009 | Intel D945GCCR Motherboard
ATX93-3405 WHEN I TURN ON THE POWER THE SCREEN SAYS -
There are many jumpers on the motherboard, drives, and such. Is there a title to the error that might possibly identify which jumper they are referring to? I have one for overclocking, one for chassis intrusion, one for ide mode in SATA, and on, and on. What does it say "before" "turn off power..." is there some kind of error name? My suggestion, get the manual for the motherboard, adn look on the page that has the picturial diagram, and identifies all the components on the board. It will indicate all the jumpers, and the default positions. It shouldn't say that though, unless something has changed. So, either you changed the jumper's original position, OR, you changed some hardware configuration that has made your current jumper position erroneous.
Feb 09, 2009 | Gateway (ATX93-9405) (ATX939405) Power...
Some MB's have a second jumper setting on the board to allow a technician to jump to a faster "trouble shooter" configuration. After any or no changes are made to the BIOS's configuration the BIOS wants the The tech to reset the jumper back to "Normal Mode" so the customer doesn't have an overclocked or "hyper"machine voiding it's warrantee. I have seen this on some mostly older boards including Intel's who are known for down speeding their MB's. Check the websit for the MB's manual and see if it tells you where the jumper is located. If not, Also try to update the BIOS to the latest version and this may resolve your problem. Hope so.
Nov 20, 2008 | Intel DG31PR Motherboard
Computers & Internet Logo
110 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
