Question about Jenn-Air JGS8850AD Gas Kitchen Range
Oven burner seems to have low flame
Broiler works fine with ample pressure, bottom oven seems to give off very little flame. Sometimes half the burner is not lit. Oven takes forever to reach temp.
    President:
  • 1,902 Answers
Check voltage to gas valve in the back of the boiler compartment. It is way in the back on the left hand side, turn on the top burners. If you do not get any volts or only 1 to 5 volts you will need to replace, It is supposed to have 24 volts to operate correctly
Posted on Feb 09, 2009
BROILER HAS NO REGULAR IGNITION DESPITE THE FACT THAT THE VALVE AND IGNITER ARE FINE AND BROILER AND ORIFICE IS IS CLEAN. GAS PRESSURE AND FLOW IS FINE. ONCE LIT (MANUALLY WITH A LIGHTER) THE FLAME W
How do you know the ignitor is fine? The ignitor for the oven is different than that of the burners. Rather than clicking, the oven ignitor will glow red. If when you turn of the oven you don't see a source of red light coming from under the oven bottom your ignitor is bed.
Aug 30, 2014 | Kitchen Ranges
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When i turn my oven on, the flames come up into
If the burner pressure is adjustable(some are not) you can use a small adjustable wrench to turn the gas orfice to lower the gas pressure. The orfice is usually located in the broiler/storage comaprtment at the very bottom of the range. It is the brass piece that goes into the burner venturri and is where the gas comes out. If your turn it clockwise it will decrease pressure & counter clockwise will increase pressure. If the flames are coming into the burner compartment that is quite an increase in pressure!!! Make sure the the range did not have the gas regulator removed. If it was then that would explain why the oven burner pressure is so high.
Nov 11, 2009 | Whirlpool GS460 Gas Kitchen Range
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE jgs968 range seems to be working fine except the oven, broiler works fine
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
The good news is that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one. These aren't cheap at $91 bucks, but you can shop around the web for a better price if you determine you need one.
Please note that sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking. That's why it's always a good idea to swap ignitors to verify you have a faulty one.
If you want to see what the part is for your oven, go to searspartsdirect.com and enter in your model number to view the line drawing for your oven along with the parts list.
Hope that helps and best regards!
Jun 07, 2009 | GE Profile JGS968 Gas Kitchen Range
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn-Air JGS8850AD Gas Kitchen Range Logo
320 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
