Question about Kenmore 23822 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
OK you washing machine genius folks, here's my problem:
Kenmore Series 70 Washing Machine (Top Loader)
Washes, agitates, drains, but when the spin cycle tries to start, I hear the motor engage, but it won't start spinning...until I open the lid, and close it again. Then, no problem.
Switch? Motor Coupling? Help!
  • 2 more comments
  • dlb94061 Feb 09, 2009
    OK, yeah, the thing isn't exactly ruining our lives...but having to go in and start the spin cycle every load kinda...well...um...sucks. ;-)
    Bump. Solutions to the top 4 current unanswered questions are easily available in previous solutions.
    AHEM. Come on, folks, this should be easy for anyone claiming to be an expert....
  • Anonymous Feb 22, 2009
    Exactly the same problem as described above. I guess I'll get a timer or find another washer on craigs list.
    thanks
  • rotorx7tt May 11, 2010
    not the switch if the motor continues to run, not the motor coupling if it is agitating. does it spin while it is in the rinse cycle? im thinking clutch or gear case prob.....
    New Friend:
  • 15 Answers
LID SWITCH
If you need further help, I’m available over the phone at https://www.6ya.com/expert/elite_9cbd96cb0728162b
Posted on Jan 18, 2013
    Novelist:
  • 117 Answers
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Posted on Feb 14, 2009
  • cherie king
    cherie king Feb 27, 2014
    I am read you post trying to find a solution to my washer problem my washer fills drains but will not agitate or spin it appears the lid switch is good and the coupler is good. what do yu think the problems is?
SOURCE:
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Kenmore 70 series washer model 22722 will not spin or agitate
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Washing Machines
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
Won't agitate or spin
Probably the motor coupling has cracked. Located between the motor and transmission/gearbox.
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Same problem
ck lid switch blocked pump would not prevent spin unless it was locked up then probably wouldn't agitate either
Jul 20, 2008 | Kenmore 22422 Top Load Washer
Kenmore 23822 Top Load Washer Logo
841 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
