Question about EliteGroup NFORCE 570 SLIT-A Motherboard
Got a trojan
Well I managed to get a Trojan from a bad download of the adobe photoshop trial, and, though I deleted it within like 9 minutes of getting it, it's done something to my computer that I can't seem to fix. It disabled system restore and tries to access the internet (which I have unplugged). About 30 minutes after it fails to access the internet, I get a force shutdown message executed by NT/Authority saying it has to shutdown because DCOM server process terminated unexpectedly.
I've run everything there is to run, adaware, spybot, spy eraser, registry booster, speedupmypc, AVG antivirus, registry defrag, chkdsk, system defrag, EVERYTHING, and I cannot fix the problem. Does anyone know a way to fix this, other than reformating? I think the trojan was called something like pronett or something along those lines.
  • 5 more comments
  • c_drouillard Feb 09, 2009
    Sorry, this is in the wrong section. I posted it from the section where I posted the last problem. Is there any way to move it to the appropriate section?
    I can attempt running it in safe mode, though I believe last time I used safe mode, it crashed anyway, and my AVG already found and removed the infected files, it just seems to have damaged my system before I could remove it.
    Yes I was already going to do it. I guess the last time I booted up safe mode I just forgot about it or something, I'm running the anti-virus in the safe mode now.
    Well I believe the scan finished, as it was not open when I came back, and yet the computer had not crashed, however I have no idea if it found anything as there is of course no GUI to read the results in. I'm running it just once more to make sure, then I'll run it in normal mode and see what happens.
    A registered version of AVG8.0. I found out that it saved it to a file in my documents called avgrep, though I had started the new scan before I found out about that, so it overwrote the results unfortunately. I'll just boot up in normal mode and see how it goes.
    Well it still is attempting to access the internet, and so I can only assume the problem has not been fixed. I'm going to just try to run all my fixing software from safe mode and see if that does it. What kind of bites is that right on this site is a free trojan remover download which I can't use on my infected system due to the fact that allowing it to access the internet will most probably allow the trojan to spread.
    The one thing I'm concerned with is that the attempt to access the internet may very well be the computer trying to fix the problem, rather than the virus trying to spread, though I don't trust it enough to try.
  • c_drouillard Feb 13, 2009
    Going to have to end up reformatting, but due to the mass amount o f data i have to transfer, I'm going to need to transfer in intervals of 20 gigs at a time, as I only have about 40 minutes before the crash, before I can reformat.
    President:
  • 778 Answers
You will have to run a full Virus Scan in safe mode with an Anti Virus program with up to date Virus Definitions.
Tap the F8 key on boot to get to the boot option screen that will allow you to select "Safe Mode", then select your operating system, then click yes on the pop up. Once in safe mode locate your Anti Virus program in your program folder and run the full/complete scan and that should fix you up.
Posted on Feb 09, 2009
  • 5 more comments
  • Frank  Fernandez
    Frank Fernandez Feb 09, 2009
    Again, you will have much greater success repairing a virus in safe mode, as you are limiting the resources that the Virus/Trojan has to propagate itself.
    I pay my bills repairing computers, so please trust me and give it a try.
  • Frank  Fernandez
    I find it a waste of time to run a virus scan any other way. And System Restore is useless for virus problems too as most viruses migrate into the restore partition immediately. I'll check back in an hour or two and see how your doing.
  • Frank  Fernandez
    What Anti Virus software are you using? It should have showed results of the scan when complete.
  • Frank  Fernandez
    Sounds okay, and good luck.
  • Frank  Fernandez
    Are you running XP SP3 or SP2 with windows firewall on, or a third party firewall? If so and windows security center isn't warning of any problems with Firwall, Automatic Updates, or Anti Virus then you should be good to go online and try to fix it, or disconnect the device from the internet and try to run your repair/tuneup utilities.
    You could also use a startup manager first thing after Windows loads and kill all un needed apps that are set to start with Windows. If you know how to safely use msconfig you can edit startup items there.
    A format and clean install will probably do the best for you performance wise though.
    Good luck and good night. :D I'll check back tomorrow night.
  • Frank  Fernandez
    Frank Fernandez Feb 12, 2009
    How did it go?
  • Frank  Fernandez
    Frank Fernandez Feb 13, 2009
    Bummer, I was hoping you would be able to recover because you caught it so quickly. Thanks for the rating and Good Luck.
Idk how to get free adobe photoshop trial in windows xp
Windows XP is obsolete and unsupported. You will only be able to do it if you can find a version that is 5 or 6 years old and with the trial feature enabled. I think that is unlikely. Having said that though .....
Adobe Photoshop Free - Download
adobe-photoshop-free.en.lo4d.com/
Jun 21, 2011 - Adobe Photoshop Free Screenshot. License: Free Trial; Language: English; Publisher: Adobe ' (24 more); OS: Windows 10 / 8 / 7 / Vista / XP ... ‎Download · ‎Screenshots · ‎Virus Tests · ‎Details
Adobe Photoshop CC - Download
https://adobe-photoshop.en.softonic.com/ Adobe Photoshop CC, free and safe download. Adobe Photoshop CC latest version: The best image editor with video editing ... Trial version. OS. Windows XP ...
free adobe photoshop trial for windows xp Google Search
Jun 24, 2017 | Adobe Computers & Internet
How to remove trojan dos alvreon
1.To stop all Trojan:dos/alureon.a processes, press CTRL+ALT+DELETE to open the Windows Task Manager. 2.Click on the "Processes" tab, search for Trojan:dos/alureon.a, then right-click it and select "End Process" key. 3.Click "Start" button and selecting "Run." Type "regedit" into the box and click "OK." 4.Once the Registry Editor is open, search for the registry key "HKEY_LOCAL_MACHINE\Software\Trojan:dos/alureon.a." Right-click this registry key and select "Delete." 5.Navigate to directory %PROGRAM_FILES%\Trojan:dos/alureon.a\ and delete the infected files manually.
Good luck
Sep 03, 2011 | Microsoft Computers & Internet
Worm/Agent.GENERIC-ONE
Trojan Generic is a downloader Trojan that sneaks into your system through vulnerabilities. Once Trojan Generic is installed, Trojan Generic downloads more malware and adware, and launches ads on Internet Explorer.
http://www.fasterpccleanclean.com/trojan-generic-removal
Dec 04, 2010 | Symantec Norton Antivirus 2010 Full...
Hi! my comp is nfected with a trojan masquerading as a security tool. it keeps popping dlhost.exe is infected with virus DOS.Jeff.812 this worm is trying to send our credit card details using dlhost.exe...
First try this but be careful:
To remove Trojan, you must first stop any Trojan processes that are running in your computer's memory. To stop all Trojan processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for Trojan, then right-click it and select "End Process" key.
To delete Trojan registry keys, open the Windows Registry Editor by clicking on the Windows "Start" button and selecting "Run." Type "regedit" into the box and click "OK." Once the Registry Editor is open, search for the registry key "HKEY_LOCAL_MACHINE\Software\Trojan." Right-click this registry key and select "Delete."
Finally, to completely get rid of Trojan, you must manually remove other Trojan files. These Trojan files can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, Trojan might create a file like
%PROGRAM_FILES%\Trojan\Trojan.exe. Locate and remove these files.
OR
If you can pass to the Windows interface you can run a Trojan remover like this one Trojan Remover at cNET. If not do it manually, instructions HERE
If your OS is Windows go to this link by Microsoft Online Scanner
also this one is a good one from TenMicro HouseCall
Oct 03, 2010 | Intel Computers & Internet
Serial number for photoshop cs2
serials for adobe adobe products do require more than just more than key. you will have to crack it which is the only way cause after inserting a key it will connect online to verify it and note that every pc has a unique code so mine will not work for you. go to website below to get your cs2 registered by downloading an activator for your product or serial if you still insist. For the first website you will have to turn off all download managers to which the site does not support and also have to scan for virus(if you are using avg it will report as trojan even if it is clean-just because of what the file does). Last but not the least you will have to enter just the product name to get the whole list of files to choose from. good luck in your hunting.below are the sites.
www.cracks.am
www.serials.be
Jul 04, 2010 | Adobe Photoshop CS2 for PC
How do I fix the dcom server launcher, the computer keeps shutting down after it's been on for about five minutes?
Click Here to Download this program (its free). Install it. Update it. Run a FULL scan of your computer (took about 30 minutes and the viruses didn't pop up until the very end of the scan). Delete ALL of them (note: you have to reboot to delete the ones in windows system 32) There will be a list of about 5-10 infections they should be similar to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\tdssdata (Trojan.Agent)
HKEY_LOCAL_MACHINE\SOFTWARE\tdss (Trojan.Agent)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters\NameServer (Trojan.DNSChanger)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\T cpip\Parameters\NameServer (Trojan.DNSChanger)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\T cpip\Parameters\NameServer (Trojan.DNSChanger)
C:\WINDOWS\system32\tdssadw.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssl.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssserf.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssmain.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssinit.dll (Trojan.Agent)
C:\WINDOWS\system32\tdsslog.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssservers.dat (Trojan.Agent)
C:\WINDOWS\system32\drivers\tdssserv.sys (Trojan.Agent)
Thanks for using Fixya!
Jan 31, 2010 | Computers & Internet
How TO Install Trojan Remover ????
Here is a Better trojan remover that is free It's called A-squared and here is a link if you want to try it http://www.emsisoft.com/en/software/free/
May 06, 2009 | Computers & Internet
How to download adobe photoshop 7.0
Try going to the Adobe website, and go to trial downloads. If you are trying to buy, you can go to the same place, or google it, and it will come up with different places to buy at.
Here is the url to go to the adobe website to it.
http://www.adobe.com/products/photoshopelwin/?promoid=BPDEM
Then on the right side, click on free trial, and it will download after it starts akami download manager.
Apr 28, 2009 | Adobe Photoshop 7.0 for PC
System startup
Eventhough you think that the trojan was gone still, That symptoms are compatible with the behaviour of a Trojan, the file Manager.exe in C:\Documents and Settings\USERNAME\Application
Data\Adobe will show as not having an icon, or author information and
everything else. Delete it. It is not from an Adobe product
Download Sysinternals Suite from http://www.sysinternals.com and run autoruns.exe to cleanup your registry manually. and go to malwarebytes.org and use it.
Aug 21, 2008 | Computers & Internet
When i try to download photo shop cs3. it says i have to close internet explorer and it isnt even opened. can you help me please?
Press: Ctrl/Alt/Delete and in Task Manager, select the Processes tab, then select all instances of 'iexplore.exe' and choose 'End Process' then click 'Yes' until there are no more. If it still says the same thing, you might have a virus or trojan horse feeding someone information on everything you're doing on your computer. For that: visit MajorGeeks.com.
Jul 11, 2008 | Adobe Computers & Internet
EliteGroup NFORCE 570 SLIT-A Motherboard Logo
69 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
