Question about Insignia NS-DV2G MP3 Player
Charging trouble My Insignia device turns off just when I play a song, and the battery indicator shows only one line of charge (like it would be uncharged) so I connect it to my computer and everything seems to be all right; the battery indicator is full and green. Also the device last too much time turning on and always says Rebuilding libary for a long period.
    Problem Solver:
  • 9 Answers
Might be a bad battery.
Posted on Feb 14, 2009
Will not turn on
If it is not down to a dead battery, (many batteries show that they charge full but they cannot hold that charge so they no longer switch on,) I would search on line for a method to hard reset the device. Remember that if you do go down that road you may lose any data stored on your device.
Try the battery first.
Nov 05, 2015 | Insignia - Flex 10.1" Tablet with 16GB...
Not sure if it is charging
the empty sign indicates that it is flat
when charging the empty box will show a green fill level
Dec 22, 2017 | Speedo Aquabeat 2.0 4GB MP3
Phone says its charging when plugged in but battery doesn't charge
Hello and Welcome to FixYa!
Well, it seems like either bad charging connection. Look, sometimes, it happen, that as soon as you plug in the charger, the charging indication starts showing that the device is under charging mode, but in real its not. You can say, that the charging animation showing on the screen is fake. Secondly, it could be due to bad charging IC in worst case, or can be due to weak battery (in most cases), And to rectify the problem, first you need to try charging the battery with some other OEM charger, Secondly do make sure that there is no carbon deposition on the battery terminals. If the problem still persists, then either the charging IC or the battery is the bottle neck of the trouble. Hope, now you get a wider picture on how to deal with the scenario.
Have a nice day,
Aug 12, 2011 | Samsung Jet S8000 Cell Phone
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
When the battery is charging, the CHG indicator turns orange. When the charging is completed, the indicator turns off. More information can be found in the owner's manual.
Jun 17, 2010 | Insignia IS-PDVD10 Portable DVD Player
Will not take a charge. took two charges prior but has now stopped
I found this online at under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Not getting Charged
If you mean the Insignia NS-BTHDST or NS-BTHDP, I read elsewhere in this forum that you can reset it and that might work. See the manual. Basically you hold the volume up and volume down together while the charger is plugged in. The instructions were vague and mine did not reset nor show a purple light as indicated in the manual.
However, after trying that a couple of times, I accidently got it to work by pressing the phone/play button twice. Press it normally, not the long press you use to turn it off and on.
So in other words, plug it in to the charger. Press and releas play. Press and release play.
For me, the charge light turns on and it starts charging. I hope this helps.
Mine is new too, sort of. It was an "open box" from an ebay seller. I may return it anyway, since it is clearly NOT behaving correctly. You shouldn't have to press buttons at all to get it to charge. I know because I have another one.
Bon chance, mon ami.
Oct 10, 2008 | Insignia Bluetooth Wireless Headphones...
battery of insignia how many voults!
Sep 05, 2008 | Insignia Sport MP3 Player
Insignia NS-DV2G MP3 Player Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
