Question about Coby 5.1 Channel DVD Player with Home Theater Speaker System System
Loud hum when I turn on power from the speaker
I can't even turn it on all the wires are hooked into there proper color coordinating port. What is wrong?
    Genius:
  • Coby Master
  • 1,673 Answers
Disconnect the device (amp or TV) that is feeding the speaker system. Turn on the power and see if there is still a hum. If the hum is no longer present, then the hum is most likely from the source.
If the hum persists, most likely the power supply has failed, or the output section has a short. You should contact the manufacture for support. They will most likely recomend that you give the unit in for service.
Jerry G.
Posted on Feb 09, 2009
Infinity tss 750 sub-woofer when powered on immediately pulls speaker in and has loud humming. no inputs hooked up, only plugged in to ac power source.
The loud humming is the sound of AC mains - clearly your amplifier is receiving an input from somewhere and possibly into the front end.
The hum could be induced by radiated energy from nearby unshielded equipment, it could be the result of an accidental hum-loop or could be because the amplifier power supply has a fault.
It is usual practice with amplifier construction to ensure unused inputs are shorted to ground by switching or by additional contacts and wiring at the input sockets. High gain high impedance inputs can cause a great deal of unwanted noise if they are not shorted.
I suggest you read the instruction manual and perhaps Google a few hints and tips about amplifiers and stuff.
Mar 28, 2016 | Infinity Audio Players & Recorders
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Velodyne dps 10 rca hums but wired is fine
The issue a floating ground that causes the hum you are talking about. What are you connecting it to that causes the hum?
Jan 07, 2014 | Velodyne DPS-10 Subwoofer
Humming sound from speakers
Hi, If you get a hum from speakers you probable don't have it hooked up right.
(+ to+ - to -) The polarity is incorrect. The best way to fix this is have wires that are color coded or has one with a white stripe on one wire.This will make it easier for you to connect properly. Good luck.
Jan 09, 2012 | Yamaha Audio Players & Recorders
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Trying to hook up the polk speakers to my hp pavilion mx70, but no audio is coming out when i connect the color coordinated wires to their correct spots
First try connecting headphones to the output to confirm there is an output. If there is , then your external speakers may be faulty or require power. If there is no output on the headphones then check your volume settings.
Feb 20, 2011 | Computers & Internet
I have hooked up my subwoofer and amp to my factory stereo in a 2011 camry. My power wire is hooked directly up to my battery, my ground to the chassis and my remote to my fuse. I have my RCA wires (RCA on...
Rewire your stereo cables as such:
Red- positive - battery
Black - ground - chassis
Remote (Yellow) - ignition switch
The "LINE OUT" should go to your SUB-WOOFER.
The while-lined wires paired with the solid colored wires are either your Front LR and/or Rear L/R.
Jun 14, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
Loud humming coming from subwoofer
This can be caused due to an increase in local interference. The hum is decreased when you plug in the satellites because the interference is spread over a longer area. You may notice that speakers tend to hum around things like cell phones and power outlets. To see if this is the case, move the speakers to another part of the room if you can, slide the desk around, plug the computer in at another room, something like this. If the hum gets louder or quieter, it is interference at your new place. This can be solved by finding a new area to set up your computer stuff at. Since it's mostly the subwoofer, try elevating it off the ground, there may be a power main running under the floor.
Sep 04, 2007 | Audio Players & Recorders
Coby 5.1 Channel DVD Player with Home Theater Speaker System System Logo
383 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
