Question about Gateway GT5242E PC Desktop
Boots to desktop stays on for about a minute or two then shutsdow
Tested the memory, hard drive, power supply and other drives does not over heat. boots to the desktop for minute or two the the video cuts out then a few seconds later it shuts off.
    President:
  • 778 Answers
Sounds like the processor is overheating. Check to make sure that the processor fan is running and that the heat snyc is secure.
Posted on Feb 09, 2009
My PC powers on and off on and off and the fans are the only parts I see running. The power supply LED is solid Green. I did notice that when I remove both memory chips the fans stay running. Beeps are...
Disconnect all storage devices, and stay "flat" with motherboard, CPU, memory and video chip (PCIE or onboard). Try to detcet and check up some warming on the chipset. Cold chips? Prepare your self for new motherboard, sorry! Try another PCIe graphics card at the end. Do you trust to your power supply.
PC Servis Kompjutera Kod Fontane Popravka Odrzavanje Laptop Desktop...
Jan 31, 2015 | HP Pavilion Slimline S5-1554 Desktop - 6GB...
The computer would not go on onle a orange light is in the start button instead of the regular green light. how can i fix this?
An amber power light that stays on indicates that the power supply is getting power to the motherboard, but the system can't process any data.
This is one of those cases where you would need to strip down the system and start with minimal hardware installed.
First remove all the PCI cards and the memory, as well as disconnecting the drives, to see if the system gives a beep code for no memory.
Next, add back the memory, one stick at a time if you have two in the computer. Connect the hard drive back to the system and see if it will boot up from this configuration. If not, then if you are using the onboard video, try an add in PCI video card.
If it still will not boot then the problem is likely to be the hard drive, mother board or processor.
You would want to try another hard drive to test. If you can boot from this configuration, then add back the other drives one at a time, then do the same with the PCI cards. At the point where the symptom returns, that will tell you which part is causing the issue.
Here is the manual
http://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-gx260_Service%20Manual_en-us.pdf
May 25, 2014 | Dell OptiPlex GX260 PC Desktop
I have an Accer Aspire x3400 and after several turn on's and forced shut downs the computer will finally boot. I most cases when the switch is pressed the light flickers but does not stay on. Fan
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm Testing & replacing the PC's power supply http://www.youtube.com/watch?v=hbNxhvm0czs One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ http://www.youtube.com/watch?v=du0Qd_3wFWM There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Apr 06, 2013 | Acer Computers & Internet
My emachines w3115 desktop won't boot up. It just beeps
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty although very rare for sata lead to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Mar 10, 2013 | eMachines W3115 PC Desktop
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Gateway gm5442 very slow to boot, 20 to 30 minutes.
You said you tried different CPU, but it was the same motherboard, right? Maybe the motherboard speed (data bus, etc.) is just slow. Otherwise, there's not much left to try if the hard drive works OK in another computer and you've tried upgrading the memory, CPU, and power supply.
May 29, 2010 | Gateway GM5442 Refurbished Intel Desktop...
HP DESK TOP M733ON WILL NOT BOOT, WOULD NOT BOOT BEFORE NEW HARD DRIVE OR AFTER NEW HARD DRIVE
That's because "not booting" only relates to the hard drive after you have eliminated the power cord, power supply, motherboard, memory and CPU of the computer. Eliminate those 5 things and in the process you will have found your answer.
Jan 03, 2010 | Computers & Internet
Acer veriton M460 will not boot up
The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
Jul 31, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Gateway GT5242E PC Desktop Logo
80 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
