Question about GE 31GT660 TV
Partial picture for 20 minutes
My phillips magnavox tv is not working right. when you turn it on you see 3 horizontal lines red blue and cant tell if the other is white or yellow then the picture shoes up only in the center section of the screen the top is black and the bottom is black it looks like the picture is folded on top of itself on top and bottom the channel is upside-down, but after a while the picture starts to unfold and then it evebtually looks normal. is there a part I can buy and repalce to fix this?
  • 15,935 Answers
Without proper callibration equipment, this is not a end-user fix.
Phillips is a brand most techs will not touch - as they are prone to re-failure.
Your best option is to find a local repair tech that will take on the workload.
There is not too much circutry in a CRT tv, and it is evident your controller is going bad.
If you feel inclined - open the shroud and look for damaged capacitors on the invertor board. Also check for cracked solder joints.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 09, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this problem is there is some
fault in your main board.When you get those lines
in your tv it should be the fault in your main circuit
board.you have to check the soldering,that is don in the
board is without any fault.Then u say about the picture
size that it looks black at the above and below the screen.
This may be due to the viewing option.your tv has various
viewing option.u would have switched up to some other view,
that's why it looks like that.select the view which u prefer.
This will solve your problem.
check this out..
thank u..
    Master:
  • 848 Answers
Hard reset- unplugging tv for about 5-10 minutes and see if that clears up the problem. Because they have microprocessors in them (computer chips) and just as like with any other operating system, they can hang up or crash. Unplugging it for awhile resets the microprocessor .
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
I have a phillips tube t.v that shows a wavy horizontal line
If the set works fine intermittently it may be a loose connection or a bad solder joint. More likely the later. Heat will sometimes make a cold or broken solder joint work. If this changes when you lightly tap on the side of the TV you have a bad connection of sorts inside. These repairs can be expensive unless you find a good repair person.
The syncronizing signals in TV's (keeping the picture locked in) are around the high voltage transformer which is usually the heaviest component attached to the circuit boards. It's stressful over time and I've seen the solder connections crack and become intermittent.
Nov 23, 2008 | Philips Magnavox 20MS3442 20" TV
Blue Screen with thin horizontal white lines
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
Magnavox 9p6040
Sounds like a solder or connection issue on the small signal panel. which is the ciruit baord on the left hand side of the set looking in from the rear of the set.
Jun 13, 2008 | Philips Magnavox 9P6034C 60" Rear...
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
GE 31GT660 TV Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
