Question about Western Digital Caviar SE16 (WD5000AAKS) 500 GB SATA Hard Drive
Is not showing up in the computer
I have had the drive about two weeks now. I installed it and it showed up under the my computer. But as of yet hadnt really used it for anything. So the other day I went to put a file on it and couldnt find on the computer at all. I have since checked the bios and it is showing up. And since adding it I havent done anything different with my computer.
  • Pierre 1 Feb 22, 2009
    I installed a 500g sata wd caviar as a data disc my bios sees it but when i try to access it in my computer and maybe format it i dont see it at all. It is not partitioned either. What if i disconnect my working hard drive and try to load windows and only go as far as creating a partition . I hope someone knows the answer
    Pierre
  • Greg Caudle May 11, 2010
    Go Start> Control Panel> Administrative Tools> Computer Management
    Select Disk Management under Storage
    Look to see if your Drive is listed and what the Status, Layout, Type, and File System it has.
    Right mouse click on the dive and click on Explore to see if your files come up. If yes, then perform a Change Drive Letter and Path.
    Let me know what the status is.
    Genius:
  • Western Digital Master
  • 1,250 Answers
Go to control panel, then administrative tool, then to computer management, then to disk management, check the status of your hard drive or check it on some others system
Posted on Jun 13, 2009
I've installed the device and the device is working properly, but it doesn't show under devices. What must I do?
Hard drives will not show up in Devices and Printers. You need to open computer manager (type compmgmt.msc in run box)
Oct 04, 2014 | Computers & Internet
My Samsung HX-MU010EA/G2 1TB portable hard drive is not working. It is not being recognised by my computer all of a sudden after about 6 weeks of use. The blue light flashes quickly but does not give...
Have a look in disk management if on win 7 or vista just type in "disk Management" in your search bar after clicking start button and see if it shows up there. If not try plugging into another computer and see what happens. If still no good you say only 6 weeks it should be guaranteed. If your data is important to you never trust just 1 source of backup maybe start copying to DVD's also. Good luck with it from Scott
May 17, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
My 320gb external hard drive has stopped working. I have used it alot with my laptop, but i hadnt used it for about a month. when i plugged it in it said it needs to install device driver software, but it...
Try connecting it to a different USB port on your computer.
Try connecting it to a different computer.
If the problem persists, either:
* the USB cable is damaged,
* inside the enclosure, the disk-drive is not functioning
(although the lamp indicates that it is getting electrical power)
* inside the enclosure, the USB-to-disk-drive adapter has failed.
If the warranty is still valid, W.D. will replace it, at no cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program; buy a new unit from their web-site, and you can get a discount, as a previous customer.
Or, open the enclosure, and remove the disk-drive, and temporarily connect it as a "slave" disk-drive in a desktop computer, to see if it is working at all.
Or, buy a new, compatible, disk-drive, and mount it into the enclosure, to make a "new" external disk-drive.
Oct 29, 2010 | Western Digital 320GB MyBook External USB...
Sony walkman mp3 nwz-b135f not showing as a device on my computer
Please dont use any of the solutions above
try this..
If the Sony Walkman Mp3 is not detected as a drive in windows explorer but shows as a portable device in Device manager,, do the following
right Click My Computer > Manage
Select Device manager
right click Walkman , which will be under Windows Portable devices
Click Update driver
Select no, not this time, click next
Select Install from a specific list... ( Advanced) and click Next
select don search ,....
Click Next
Put a check mark in Show compatible ...
Select USB Mass storage device and click next
Conitnue and the device will be detected as a drive in windows explorer
amisadath@gmail.com
Jul 02, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
Not showing my external hard drive
you might have to log off the computer and log on again with another user. the user that you installed the data under is sometimes the only way to go back and retrieve it. try this first.
Mar 02, 2009 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
1TB external hard disk does not appear in XP
right click on my computer and select manage.
Go to disk administrator. Right click the drive and have it put an ntfs partition on it. It will then show up in my computer.
Jan 12, 2009 | Western Digital My Book Essential Edition...
Install a disk in drive F?
Download this file from PNY to reformat your Flash Drive. It should work after that. Get the file here:
http://www2.pny.com/support/media//Files/06c3418a-bd4a-4a67-a7b7-f4415a58338a/Pre-test_v1.zip
Aug 22, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Computer doesn't recognize drive anymore
Advice,
Sounds like you are swapping this external drive between two PC's. Why don't you do this! Get it connected to one of your PC's preferrably your desktop. Once you get it connected and it is able to be read and you can read files or acces it! Share it out, under Windows XP you can share out drives, files, printers etc.
Once you do this both PC's can share this device without you having to swap between PC's manually!
I can walk you through this if you need further help, but if this persists, it sounds like your files are corrupt on this drive you may need to reformat the drive.
Nov 24, 2007 | SimpleTech Pininfarina 80GB External USB...
Western Digital Caviar  SE16 (WD5000AAKS) 500 GB SATA Hard Drive Logo
790 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
