Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Pilot light will not ignite unless cable is tensioned up
I have an Evcon house furnace in a hall way enclosure inside my house. It is model #BGM08012CX. The pilot light will not ignite unless you push up on a cable that connects to a brown colored plastic box inside the front cover, but on the front of the furnace. The other end of the cable goes to what looks like the incoming gas valve. Unless tension is kept on the cable close to the connection, the gas will shut off and no heat. I guess it is just a bad connection but can that brown box be replaced and if so, where do I get one? Or do I have to replace the whole furnace? Thank you for any help you can give me.
Bert Brown
    President:
  • 1,902 Answers
No you do not have to replace the whole furnace, the bad news though since it has something to do with the gas, This is the ignition module (or brown box), you have to be a certified HVAC-R Technician or company to buy the part or do the repair
Posted on Feb 09, 2009
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Why wont furnace light past the thermol coupler
There is really not enough information here to go on. If this furnace has a thermocoupling, the pilot will need to be lit manually. Follow the manufacturers lighting instructions carefully. If it still will not light you may have a dirty pilot assembly or a defective gas valve. Modern furnaces do not use a thermocoupling. There is no standing pilot light. Each time the furnace needs to be lit it will be done electronically. Many reasons why it wont light in this case. Safety control could be preventing it from lighting for safety reasons. A bad ignitor, ignition module, circuit board, gas valve, pressure switch, gas supply, induced draft motor, blocked or restricted flue pipe, cracked heat exchanger, dirty flame sensor, ect. ect. ect.
Oct 07, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace
Did you clean the pilot orfice?? It has a very small opening about the size of a hair. You may have to use a needle to open the opening....Are you getting gas to the pilot orfice assembly from the Gas Valve when you set it to Pilot?? If not then check the pilot adjustment screw on top of the gas valve at the pilot tube. CW decreases flow.
Nov 17, 2013 | Heating & Cooling
For sensor if you mean thermocouple that sits in the pilot light I say this is usually the problem. The thermocouple needs to heat up to a preset temp before it will allow the gas to remain on. Does the pilot light stay on? If so make sure you turn the gas knob to on from pilot/light
Oct 15, 2013 | Heating & Cooling
Evcon furnace pilot light keeps shutting off
First check flame sencor is clean , check pilot is not blocked may need cleaning out , check hoses to pressure not split of blocked , jump out pressure switch see if it lights then , check air filter is not blocked .
Mar 16, 2013 | Heating & Cooling
I have a EVCON furnace DGAT070BDC. I replace the igniter control, the gas valve and the thermostat. Same problem continues: glow stick works, then the pilot lights works.The igniter control clicks...
You may have a dirty/rusty burner that is clogged or your gas valve
manifold pressure setting may be too low. Normal manifold pressure
is 3.5 inches water column on natural gas furnaces. ( 1 psig is equivalent to 28 inches water column). Pull and clean burner. Also
check and clean pilot assy. including flame sensor (if present).
Please let me know.
Oct 24, 2009 | Coleman Heating & Cooling
Coleman Evcon model DGATO70BDC Starts to run then stops?
What you have is an ignition problem and your unit is shutting down on safety.
May 01, 2008 | Heating & Cooling
Heating & Cooling Logo
102 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
