Question about Samsung LN-S3241D 32 in.LCD HDTV
Dtv antenna is not getting in fox or nbc or pbs create channel
I do not have a cable jack in my apartment so I have a hg antenna. I used to get ch:2,4,9,11,11.1, three or four of 17, 23 and 45. I noticed a few days ago i was missing the 17's, when i manually change to the channel i just get the air channel of fuzzy weather. I did auto channel scan a bunch of times and now i do not get 9 or the 11's and i picked up ch. 5.
i bought new antenna but has not solved problem, please help
5 Suggested Answers
  • 52 Answers
SOURCE: samsung HP-S4253 black screen, with sound
The problem is due to the broadcasting format of the station. I had an over the air box which I used to receive HD programming and my PBS station went away after a year or so of use. Turns out they updated there formats and the box could no longer receive the video signal, sound still worked. There were enough people in our area who started to complaine to the station and they quickly resorted back to the old format. Technology, some people skimp, others due it right. My HD tivos never had an issue with either format. So time to get an external tuner or difference service.
Posted on Apr 21, 2008
  • 197 Answers
SOURCE: No PBS signal
drpends on were you live they all ave not converted over give it time
Posted on Jul 01, 2009
  • 304 Answers
SOURCE: we get no signal from the air antenna, cable,or games etc.
You have a bad Main bd. Have a trained Samsung tech repair the tv.
Posted on Jul 16, 2009
  • 734 Answers
SOURCE: My Samsung is hooked to
You can only rotate your antenna to get the maximum number of stations and have one list of stations.
Posted on Dec 11, 2010
I can't get local ABC, CBS, PBS or NBC with an antenna, but I get like 10 Ion channels why? I have tried several antennas with no luck?
The signal recently changed to digital. You need a digital tuner in order to receive the new signal.
Aug 22, 2015 | Televison & Video
Had my channelmaster 4046 HD hooked up to a vizio tv and got all major channels. Now have hooked up my antenna to an RCA tv and can't get NBC and local FOX station is jumpy
The tuner in the RCA has poor sensitivity. Radio Shack sells a inline amplifier that may help, make sure you can return it if it doesn't. Move the antenna outside if possible and as high as possible, that may help. Good Luck!
Feb 14, 2014 | Channel Master CM-4046HD MODERNtenna...
Cannot get NBC on my channel master
Your signal strenght is too weak either try moving the antenna to a different location. If that doesn't work then you may need an outside antenna. The link below will tell you what stations are available at your address and what type of antenna is necessary.. TV Fool
Can my Panasonic TC-P42X1 receive digital channels without an antenna connected? It sounds like a stupid question considering its a high-def TV, but I'm having troubles getting the TV to pick up...
No.Tv can't pick up any reception or receive any free AIR broadcasting tv channels at all if tv have no antena hook up to a tv.Buy a better antena design to used like a Digital atenna,will solved this problems.
Aug 21, 2011 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
I am not a cable television subscriber. Nonetheless, why can't I get my local public television station when this television set tunes in all other local television stations (local ABC, CBS, NBC, Fox...
Some flat screen tv's have two inputs, one for digital and one for analog reception. If your local public television station is analog, then you'll need a signal input on the analog input.
You might try temporarily moving the input from the digital to the analog then doing a new channel scan to see if this picks up the PBS station. You'll have to rescan again, when you move your antenna lead in back to digital.
May 16, 2011 | Televison & Video
Can't seem to add HD channels to Mitsubishi WS-65513
You need to run an external antenna feed to the air DTV input jack, bottom left. You can use your loop out if you already have an antenna connected to your antenna A input jack. Create a DTV device, then run your antenna setup for DTV.
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Cannot get local channels back after dropping cable.
Are you positive that your city has not done the Digital Conversion? Some Cities are doing it early before the February deadline. Also make sure you are tuning in to the correct channels. Meaning that if on your Cable Provider ABC was on Channel 3 that does not mean that ABC with still be on Channel 3 after you have your Cable turned off. Most of the Time the Local Stations Tag will let you know what channel its on. It will be something like "KWAS ABC 27" So on your TV you would Tune it to channel 27 to get ABC and the same fore NBC , FOX, CBS , etc...
I hope this helps Take Care =)
Dec 07, 2008 | Televison & Video
Unable to detect some local DTV channels
chec kthe settings
they might be at fault
Sep 06, 2008 | Computers & Internet
Tv guide/tuner problems
Most likely the TV Guide is broadcast from the OTA PBS channel. I don't know why its being lost. I'm thinking its probably a firmware problem of some sort. Adding the PBS channel back in, making sure the signal comes in ok and leaving the TV off for a while might help.
Dec 25, 2007 | LG 26LX1D 26 in. LCD HDTV
Samsung LN-S3241D 32 in.LCD  HDTV Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
