Question about GE JE1860 Microwave Oven
Power loss then surge GE JE 1860 Microwave
The microwave periodically appears to lose power: the fan slows, light dims, and then if I "bump" it it goes back to normal. Any thoughts? The problem is very sporadic. The microwave is about 8 years old.
Any chance there could be a compromised ground somewhere, and if so where?
Robert
    Novelist:
  • 140 Answers
Well it does appear that you have an intermittent problem. I do not think that there is a loose ground problem, but there is a thermal switch attached to the case of the magnetron that resemble the thermal switches in wall gas heaters. Like the one in wall heaters they tell the heater when to shut off and on. If that switch begins to open or is trying to open it will make it seem like your microwave wants to shut down. Of course that is just one solution which I think is the best. By the way that thermal switch only has two wires that go to it and resembles an oversized watch battery when it is out. What could cause that also is if those two wires which are connected with plugin spade terminals have become loose due to the vibration of the magnetron over the years. To cover all your bases at once, with the power off, take the cover off and reseat all the spade connectors that you can see and get to. Anything in line with that switch or with the power coming in at all can cause the same thing. Let me know if there is any other question that you have.
Posted on Feb 09, 2009
Microwave causes lights to dim and slows down
Power surges should be checked with a voltmeter, however, I repaired a 30 year old MW doing same thing. Took out the control board, examined solder connections, found a suspicious solder joint, that had an incomplete circle around connector, added a little solder, works like new, friend amazed!
Jan 29, 2014 | GE Microwave Ovens
Microwave JE 1860 has been making a loud noise for several months. Today it quit. Nothing works. No light. Turntable does not turn. Nothing on the display ... not even the clock. The unit was purchased...
Unless your personally attatched to this oven I would recomend you start shopping for a new one. Take the cover off and look for any fuses inside the front door area or on the control board, If they are bad replace them if none there then get a new one as they are more expensive to repair than replace. Most likely your magnatron shorted out and took the circuit with it, but check your house fuse as well on that circuit to be safe. A magnatron runs around 90bucks part only.
Jul 01, 2011 | GE JE1860 Microwave Oven
We have a ge 1860 micro wave oven and it is not heating, after a period of time it indicates sensor error, can you help me.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
]0]0]0]0]0]0]0]0]0]0]0]0
Sep 12, 2010 | GE JE1860 Microwave Oven
Our sylvania microwave model sr11092b received a power surge that blew the internal fuse and would not run (it also fried the power converter in my rv)\r\nReplaced power converter, replaced internal fuse...
I had the EXACT same symptoms with my Sylvania SR1109sb after a power surge.
After some digging around I thought what the heck let me try holding down the Reset button and do a power off/on cycle and what do you know it worked !!!
Just pressing the Reset did nothing until the cycle off and on.
Ron W.
Jun 11, 2010 | Microwave Ovens
My JE 1860 microwave starts working when I open the door.
It sounds like the door switch is bad. It may be that the switch is shorted inside. I would think it may really run with the door open, and microwave you.
Mar 06, 2010 | GE JE1860 Microwave Oven
I have a GE JE 1860. Someone ran the microwave for 15 minutes with nothing in it. Now it doesn't work at all , no power, no lights, nothing. Is there a fuse that may have gotten burned out? Is this...
There is a fuse and cavity thermal fuses as well as one on the magnatron that is supposed to reset itself.. The fuse is behind the control panel and the cavity fuses will require removal of the cabinet. Did you check for power at the plug?
Eric
Jun 20, 2009 | GE JE1860 Microwave Oven
GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 03, 2009 | GE XL1800 1100 Watts Microwave Oven
Slow heating; sluggish fan; low interior light
The main power supply may have a fault. Also, the HV supply may be weak at the same time.
Jerry G.
Apr 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpaceMaker JVM XL1800
Sounds like the ERC board failed. It maybe covered under warranty, check that first cause a new ERC could cost around $150-$200. Anything electric can cause the .."what the*^&% just happened syndrome.
Dec 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JE1860 Microwave Oven Logo
131 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
