Question about Vizio L32 32 in. LCD HDTV
How to get digital signal without cable or convertible box
In vizio L32
    New Friend:
  • 56 Answers
You can try to use the antenna for OTA signal. Use the connector labeled as DTV and then go to the main menu to scan for the channel.
Posted on Feb 16, 2009
Vizio L32 stopped working.
I have seen this many times. The tv most likely has run its course. It could be the power supply or a lamp. Sounds more like a lamp, as you still have lights on your set. check around and get some prices on a lamp. you can have a local shop install it for you. or just replace the set.
May 03, 2010 | Vizio L32 32 in. LCD HDTV
How can i get by without using a convertible box
what are your intentions, i have one t.v. that is hooked up to a HD channel changer, where i get a HD signal coming Thur, the other t.v. has no HD box at all and it runs str8 off of the cable,but i do not get a HD signal with that, in canada the setup is different here the HD signal comes right Thur the cable lines here, also have ya ever thought of hooking up your t.v. to a antenna, i've picked up signals of HD for free, and the picture quality is superb to that of cable company, anyways good luck
Mar 11, 2010 | Vizio L32 32 in. LCD HDTV
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Aug 12, 2009 | Vizio L32 32 in. LCD HDTV
The digital programming here and I can't get any channels clearly
Well, there is nothing wrong with the TV itself. The signal is too weak to get enough digital information to complete picture and sound.
You may need a better antenna for reception.
There are some long range digital antennas and antennas that will receive signals in all directions.
It's the best way I know of to solve the problem.
Jun 15, 2009 | Vizio L32 32 in. LCD HDTV
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
No signal when hooked up with a digital cable box
turn your tv to channel 3 and then try 4 one of these should work . Also make sure that you have it plugged in the right coax jack in the back
Mar 05, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
2,783 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
