Check to make sure the fuse is good and you have power going to the switch and then to the wires (brown for positive and black for negative) in the bilge area using a 12 volt tester. If you have power to the brown wire while grounded to the black wire then the pump will need to be cleaned, have the impeller replaced or replace the pump. The pump is located in the rear compartment attached to a board mounted to the inside bottom of the boat at the center near the transom.
SOURCE: Bass tracker fuse descriptions
I was trained at a tracker dealership and that is one of their faults. The best way to find the fuse for the bilge pump is to look on the back of the bilge switch and trace a wire to the fuse panel. Most of the time they are color coordinated so you can match fairly easy without trying to manually probe for the wire.
SOURCE: I have a Nitro 929 dual console bass boat 20 ft. I
Disconnected all the circuits at the battery end. Reattached each circuit one at a time . I connected the hot lead first then used a fluke voltmeter on mil amp setting -used the red lead to the end of the load wire black negative end and the black fluke lead to the negative battery post -- registered the current draw and found the circuit that was draining battery then went to each device on the circuit in this case it was a bad bilge pump motor for some reason it was shorting out but not enought to blow the circuit fuse.
