The selected 'Find your product' may not be the exact description of the my Vitra toilet, as the tank lid is not totally 'flat', it looks more 'rounded' than 'flat'. I hope this helps you to solve my problem. Looking forward to your answer, thanks heaps!
SOURCE: Vitra elongated Toilet
Sounds like you need to replace the fill valve assembly. It is not expensive or difficult, just a little messy
SOURCE: I have a dual flush vitrA and it leaks
You will need to replace the flapper in the tank, its very simple.
SOURCE: Replacement part for VitrA cistern
I trust you mean the "Flapper Valve". They are available and most hardware stores.
Get a Universal type as they fit most units. Take the old one with you. If you turn the water off at the wall it will stop it from running while you're away
SOURCE: VitrA dual flush toilet doesn't flush enough water
maybe by shortening the chain length on the flapper valve might help
SOURCE: I am trying to find
Hello. Call your local plumbing shops. Some of them store all of the used parts for this very purpose. If they don't have a lid, they may have a source nearby. Joe
