U need to open the 4 screws on the sides
then there is one screw in the center at the bottom
the u also need to unscrew the nut screws on the vga connector.once done
press the top of the panel near the keypad & the front cover will come off
similar is the procedure for the back cover.
when you try to lift the top cover make sure not be hasty, open slowly s there is a film connector for the keypad that is connected to the main board,take care not to damge it
once you have acess to the main board
loosen 2 screws on the mainboard & then press the outer side of the main board.there is a 100 pin connector that connects the main board to the dlp engine.this is the cause of the problem that you mentioned.this should fix your prob
Please dont forget to vote this answer was helpful
Many thanks
After using the projector for one year , lamp replacemnt indication came on used for few more months, light started to flicker .Bought a lamp from ebay, but it does the same thing and also shows the lamp need to be replaced.
cual es el valor de main board optoma ep-716 . el problema de mi proyector es que despues de uos iinutos empieza a titilitar la imagen y no se puede apagar manualmente ni por control remoto
