Question about Navman GPS
Vavman fully charged but will not work in car. All I get is the accept agreement then it tries to find the maps then goes straight back to agreement.I was using it on a long journey, one minute it was ok then nothing. J McDonald
  • apiian Feb 09, 2009
    Thank you I will send off the GPS, where do I send it??
    Genius:
  • 1,011 Answers
Sir,
Check all the connections properly. Click these link for the guidance to solve your problems...
Link 1
Link 2
Link 3
Thanks Good Luck
Posted on Feb 09, 2009
  • 744 Answers
Hi...you need to send ur device  to repair shop .... if the fuse is the problem in ur devicemeans it cant be easily replaced also other components inside need to be checked....
NDS Lite Turns on but then after a few seconds turns itself off
Check the battery is fully charged, its always worth fully charging a battery before you start soyou can route that out.
Check the cable is fully in for the bottem screen, if it is not in the ribbon connector all the or at an angle somtimes this can happen, while checking that you might as well check the other cables as well just incase. let me how it goes.
Jan 18, 2010 | Nintendo DS Lite
Navman S50
reflash the gps, or update your maps and you should be set! if nothing seems to work send in for warranty, what options does ur gps give you for connecting it to a pc or other device?
Jun 05, 2008 | Navman Personal Interactive Navigation GPS...
Navman s-80 not starting up.
Did you tried to reinstall software with SmartST that came with the package? Mabe it will work.
Mar 18, 2009 | Navman iCN 530 GPS Receiver
06 pt cruiser dtc p0108,p0113,p0123,and p0508 car will not start
P0108 (M)
Manifold Absolute Pressure/Barometric Pressure Circuit High Input
MAP sensor input above maximum acceptable voltage.
P0113 (M)
Intake Air Temperature Circuit High Input
Intake air (charge) temperature sensor input above the maximum acceptable voltage.
P0508 (M)
Idle Air Control Motor Circuit Low
Idle Air Control Motor Circuit input below acceptable current.
THESE DIFNITIONS ARE FROM THE FACTORY REPAIR MANUAL, LOOKS LIKE YOU MAY HAVE A WIRING HARNESS PROBLEM OR DISCONNECTED COMPONENTS, CHECK THE IAT AND MAP SENSOR AN MAKE SURE THEY ARE CONNECTED.
Mar 15, 2009 | 2006 Chrysler PT Cruiser
Our GPs came on and told us that map update was needed with online address. Not having time to update, it came up with agreement which was accepted then went off and will not come back on. Thanks for...
We saw one of your quick testimonies about some small screws so my husband took off the trim around the GPS and accidently found a reset button which he pushed. It came on and worked all day
Jul 05, 2008 | Garmin GPS
Model s50 safety agreement shows then map loading starts then it goes back to safety agreement
contacted navman, seeing it was under warranty i have to send it back
thanks
DENISE
Jun 30, 2008 | GPS
Navman S50 Sreies
ok..so..do a firmware reset, and you should be good to go
Mar 22, 2008 | GPS
Problem with my Navman s50
hmmm..sounds like you are suffering from a firmware issue..have you downloaded any updates recently?
Mar 22, 2008 | GPS
Navman S50 wont boot
Goto the navman site 'www.navman.com.au' and download the service pack for navdesk. this will fix the problem
Feb 08, 2008 | Navman Personal Interactive Navigation GPS...
GPS Logo
18 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
