Question about Lenovo 3000 N100 Notebook
Power connection broken
The problem: When disconnecting the power cord from the laptop, somehow, someway, the actual plug unit was dislodged from the laptop itself. Unfortunately, this was not noticed when it occurred and the part is missing. This part would normally allow the power supply to make connection with the cord connection. We can see the gold metal power connections surrounded by yellow plastic casing, but I'm quite sure there had been a silver/grey surrounding part into which the cord connected.
This computer is 4 months past warranty.
  • 2 more comments
  • Dan Eisch Feb 09, 2009
    The Notebook is a Lenovo 3000 N200
    So our question is very simple. How can we get the notebook fixed so the power cable will again plug in so the system will operate. Obviously there is a part that was broken and is now missing. the notebook is used by several people so we have no idea how it happened nor what happened to the part that was a part of the system and is now missing.
    As "TampaNative" said it is the jack that is missing/broken and needs to be replaced.
    Where can we get the part that needs to be replaced on the system board?
    Do you have any idea where we can get the part that needs to be replaced on the system board? We may be able to do it without having to go to a service center if we can get the part. Or we can bite the bullit and pay for the replacement at a center, but hope they would not opt for replacement of the entire board.
    Thank you for your prompt response to our problem.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Ok so what is your question?
    President:
  • 778 Answers
Sounds like the DC jack on the motherboard is broken. The jack is very inexpensive, but difficult to replace as it's surface mount soldered to the board and the laptop will have to be disassembled or the plastic case cut/modified to replace the DC jack.
Posted on Feb 09, 2009
  • 2 more comments
  • Frank  Fernandez
    Frank Fernandez Feb 09, 2009
    You are very luck, as your DC jack plugs in via a harness and will not require soldering. There is one on ebay at the link below.
    http://shop.ebay.com/items/_W0QQ_nkwZlen...
  • Frank  Fernandez
    Please verify that yours looks like the one pictured on ebay.
  • Frank  Fernandez
    Frank Fernandez Feb 10, 2009
    Thanks for the great rating!
  • Frank  Fernandez
    And you're welcome.
Acer m5-581t-6807 ultrabook won't power on
Disconnect power cord. Please disconnect battery. Hold down power button for a minute. Connect power cord only. Restart it.
Jun 24, 2013 | Computers & Internet
Dc jack of labtop getting vey hot
A common weak spot on most laptops is the DC power jack. If someone trips on the wire while you have the power adaptor plugged into your laptop, chances are that the power jack will get damaged.
On most laptops the DC power jack is soldered directly to the motherboard and there are only three or four small pins holding it in place. Unfortunately that makes the power jack quite weak. Any sideways pulling of the DC power cord while attached to the laptop will usually dislodge at least one of these pins, breaking the solder around it. Modern laptops use quite a lot of power, from about 70W to 120W or even more. The bad electrical connection from the dislodged pin will cause sparks and heating that will eventually burn a hole through the motherboard and can even be a fire hazard.
The usual signs of that are:
  • The battery is not charging properly or stays at half charge despite that you have been using the power adaptor.
  • The screen flickers (the brightness is changing) while the power cord is plugged in. This is caused by the laptop switching between DC power (screen is brighter) and battery power (screen is dimmer).
  • The DC plug gets hot after a few minutes of use and may even smell of burning.
  • There are "scratching" sounds coming from the DC jack.
You need to take the unit apart and check/resolder the DC jack on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 15, 2011 | Computers & Internet
I just refilled my ink cartridges and for some reason the printer still flashes no ink, any ideas?
  1. Press the On (c00636182.gif ) button to turn off the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Connect the power cord to the back of the unit.
  4. Press the On (c00636182.gif ) button to turn on the unit.and hold it down 10 se
this are the usual procedure..some do it by actually power off ..disconnect power cord..hold down the button ..and connect power cord with the button pressed..and after it powers..release the button ..try it both way s..the issue is that you probably used refilled cartridges and it needs to reset the counters..
Jun 02, 2010 | HP DeskJet F380 All-In-One Printer
HP laptop zv6000 won't charge battery
Get the Internal Power Unit checked as i can see its not been able to communicate each other.
May 03, 2010 | HP Hewlett Packard Pavilion DV9500T 17"...
My ACER 5570z will not start up. When power cord
You most likely have a broken DC Jack on the motherboard. Thus, the battery cannot get a charge and the power supply is not making a connection to the system board because of the broken DC Jack.
Good Luck
Sep 29, 2009 | Acer Aspire 5500 5570-2609 Laptop
The fax log will not load when prompted
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Wish
Jul 31, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Toshiba A205 won't charge unless I physically hold cord in
The most likely problem is the power socket on the laptop, it may be just a dry solder joint and needs to be resoldered or it may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars. If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
Jun 12, 2009 | Computers & Internet
Garmin nuvi 12 volt power cord
Could be the cord or your car plug. Does it fit snug? I have a 1996 Acura TL and the way the cigarette lighter is designed, I have to give it a bit of pressure so it makes good contact. try your unit in another vehicle and see if that solves the problem. If so, it's your car's cigarette lighter connection.
Jul 21, 2008 | Garmin nuvi 200W GPS Receiver
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Power issue
The power cord might be bent or screwed up. Or option two, the actual power connection in your laptop (i.e. the place where you plug in the cord to the laptop) could be broken on the inside.
Worse case scenario, it could be both.
If it is just the laptop cord, try another connection cord that will plug into your laptop. If it works, buy a universal adapter.
If it doesn't work, and you notice that when you plug it in to the laptop, it kind of wiggles around a bit or seems loose on the "inside" of the laptop ... you might need to take it in to a shop to have a new power connector sodered into place in your laptop.
Best of luck.
~Ominious Depression
Jan 07, 2008 | Dell Inspiron 1525 Laptop Jet Black
Lenovo 3000 N100 Notebook Logo
105 people viewed this question
Top Lenovo Computers & Internet Experts
Brian Sullivan
Brian Sullivan
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
