Question about Microsoft Windows XP Professional
Network sharing issue
I posted this once, but I think it ended up in the wrong place so I am re-posting it...
I have a PC (running XP home) with an external HD and a printer attached to it (USB).
Both are set to share with the computers on the network and ''Allownetwork users to change my files'' is checked as well for the externalHD.
I have a home network through my wireless router, and a total of 3computers access the WiFi (the above mentioned computer and 2 others).I would like the 2 other computers to be able to share the printer aswell as the external HD of the desktop. Currently both computers areable to print through the printer and both computers were able toaccess and use the external HD - great.
Something happened about a month ago where one of the computers(running XP Professional) stopped being able to access the HD. It stillcan print but it gets some errors accessing the HD:
The HD is not accessible.
You might not have permission.
Not enough server storage is available.
There should not be any permission issues - it is allowed on thedesktop and in fact the other wireless laptop can access the HD. Itdoesn't seem to be a connetivity issue b/c it shares the printer tothis computer just fine. There is plenty of space on all the computersas well as the HD
What I tried was to delete the HD from my network places and then re-instate it. That didn't work either.
Any suggestions?
Thanks,
Michael
  • yschlussel Feb 09, 2009
    well, I typed 127.0.0.1 on both computers and the response which I got was '127.0.0.1 is not recognized as an internal or external command, operable program or batch file.
    I don't know if it matters that it is completely wireless (?)
    Anyway, I found the IP address of the main computer and pinged it from the troubled computer and I had all the packets received with 0% loss.
    I guess that is OK
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Do a loopback on the network card to ensure it is in good working order. Get to the DOS prompt and type in 127.0.0.1. Hit return and see if all the packets come back. Then if that is ok, find out the IP address of your computer with the hard drive it is accessing (ipconfig /all) at the dos prompt. Then do a ping xxx.xxx.xxx.xxx on the troubled computer substituting xxx with the address of the computer with the hard drive on it and see if it comes back ok. This will rule out the network card and we can narrow it down to something else.
    Genius:
  • 1,605 Answers
Check the all of the computer you have, make sure they are all in the same workgroup. and have same users rights from the share folder, both on the HHD and the printers.
Posted on Feb 10, 2009
Make 2 pc's see each other
This is a common issue with XP and later versions of windows. Check that both computers are in the same workgroup.
On XP right-click My Computer, select properties, go to the Computer Name tab and check the workgroup name.
On Win7 right-click My Computer, select Properties, click Advanced System Settings, go to the Computer Name tab and check the workgroup name.
If the workgroup name is the same on both machines but neither come up in My Network Places then try changing the workgroup name to something else on both machines and restarting them, this usually clears up that issue.
If they still don't show up check that you have Network Location Awareness and File And Printer Sharing turned on on both machines.
On Win7 this is checked under Network and Sharing Center, Change Advanced Sharing Options. Make sure that Turn On Network Discovery and Turn On File And Printer Sharing is marked for the current profile (Home or Work, normally).
On XP go to Network Connections, right-click the connection for your LAN and select Properties, make sure that File And Printer Sharing For Microsoft Networks is checked. Then, go to Administrative Tools, Services and make sure that the Network Location Awareness service is running.
Both machines may need to be restarted after this, but that should fix the issue. If not, please let me know.
Jun 09, 2012 | Computers & Internet
VISTA Business cannot 'see' XP machine in same workgroup
Check that the two machines are in the same workgroup on network settings.
Oct 14, 2008 | Microsoft Windows Vista Business DVD...
Problem connecting to WNR2000 on laptop running vista
Perform the task below on the wireless VISTA computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 26, 2009 | NetGear WNR2000 Wireless Router
About connectiong two pc.
You can connect the computers with a serial cable, or using hyper terminal. If you have a home network, most windows operating systems will aid you to setup a home network so that you can share information
Jul 09, 2009 | Microsoft Windows Vista Ultimate Edition
No internet, no network, can't Restore
I suggest you get some guided help with the removal by clicking here or here or here or here
Follow the instructions as well as you can, make a post to only one forum, and wait for a response before making another post. Someone will take you under their wing and guide you through the process until your system is cleaned up or you stop responding...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 22, 2009 | Microsoft Windows XP Home Edition
XP network sharing problem
Hi!
Try this, go to control panel and then system. The go to advanced tab and device manager. See if you have any "YELLOW ?'s" fix those that are part of the printer.
You will see your entire computer there. from HDD to Printers.
If no yellow ?'s, then go get the new drivers for the printer.
I also do not know if you defrag on a regular basis or not. That is a "MUST" and at least once a month if your network has allot of usage.
Another item to look at is this. When using the computer, click "CTRL/ALT/DELETE and look at the performance tab. See how much of your computers processor is being used. You may be maxing it out and then you must clean computer up. But, overall it sounds like a driver issue or device management.
Mastersage..........
Feb 09, 2009 | Linksys Network Everywhere NC100 Network...
Wireless router
I cann't get my desk top and my laptop to connect so I can get to the internet I'm running a 624 router in the system
Aug 24, 2008 | NetGear WGT624 Wireless Router
File Sharing with Home Network...only one pc talking
The message for an unplugged network cable, means you have enabled wired network, but the cable isn't there. No problem if you are connected wireless.
To be able to access files on computers over your network, you need to enable filesharing for the desired directories or disks.
Right-click the directory or disk, go to sharing and set the correct settings. Maybe you have to allow for network sharing the first time.
Please post some feedback
Apr 22, 2008 | Dell Inspiron E1505 Notebook
Computer sharing
Initially, I would suggest that you:
1. Make both members of the same workgroup;
2. verify that the Subnet Mask are identical to both PCs in their networking configuration; and
3. verify that the Folder or files are shared by viewing the folder or files properties making making sure that there is a check mark on "Share this folder on the network and/or "Allow network users to change my files".
Should the above be not corrective of your concern, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 09, 2008 | Computers & Internet
Setting up 16 port switch
Dear This is the step You can get a complete home network up and running in 10 easy steps. Here's a summary of what's involved: Take stock of your existing hardware. If you wish to share an Internet connection using Internet Connection Sharing (ICS), choose which computer will be your ICS host. Decide what type of network technology you wish to use. Make a list of the hardware you need for each computer. Install the network adaptors and install your modem on the ICS host computer. Physically cable the computers together. Switch on all computers, printers and other peripherals. Make sure the ICS host is connected to the Internet. Run the Network Setup Wizard on the ICS host. Run the Network Setup Wizard on the other computers on the network. Let's take that step by step. 1. Take stock of your hardware Note each computer's location and its hardware, including peripherals such as printers and modems. 2. Choose your ICS host If you wish to share an Internet connection between your computers using Internet Connection Sharing (ICS), choose which computer will be your ICS host. The ICS host has a direct connection, either by dial-up modem or high-speed link, to the Internet and provides access to the Internet for other computers on the network. Ideally, the host should be a computer running Windows XP. I'll assume you have made this choice in the following steps. Apart from XP's easy handling of ICS, by using an XP computer as your ICS host you get the benefits of using the Internet Connection Firewall. 3. Choose a network technology The most common choices are Ethernet and wireless LANs. For an Ethernet LAN you will need to install a network interface card, or NIC, in each computer and run cabling between the computers. If you don't like the idea of opening your computer to install a network card, look for a USB adaptor instead. Depending on the size of your network, you may also need a network hub or router to provide interconnection between PCs on the LAN. Two PCs can get by using an RJ-45 crossover cable; three or more computers require a hub or multi-speed hub (called a switch). If you have a high-speed Internet connection, a high-speed router is a good option. The Network Setup Wizard includes links to detailed advice about configuring your network, including help on designing a network layout to suit your home. If you opt for a wireless LAN, you'll also need a NIC for each PC (there are versions which use USB adaptors as well). The big benefit for home environments is that a wireless LAN does away with the need for cabling. On the down side, though, wireless LANs tend to be slower, less robust and appreciably more expensive than traditional Ethernet LANs. In particular, wireless LANs do not always live up to their stated working range, and you may find factors such as your home's construction and design, plus interference from other devices affect your wireless LAN's performance. You may need to add an expensive Access Point to extend the range of the LAN and, even so, it may not be sufficient. The bottom line is, if you decide to go the wireless route, make sure the store will refund your money if the LAN will not provide reliable performance within the specified range. 4. Make a list of hardware needed Make a list of the hardware you need for each computer, not forgetting any cabling, and buy it. If you're a little dazzled by the choices and configurations, consider purchasing a networking kit. These kits contain all you need to set up a two- or three-PC network. If possible, look for hardware which features the Windows XP Logo, indicating it is fully compatible with XP. 5. Install the adaptors Install the network adaptors and install your modem on the ICS host computer (you can also let the computers connect to the Internet independently by installing modems on each). 6. Cable the computers Physically cable the computers (and hubs or routers) together. Of course, you won't need to do this if you've chosen to go the wireless route. If you're installing an Ethernet network and have a lot of cabling work to do, you may prefer to get a professional to come in and do this work for you. It won't be cheap, but you can be sure you get the job done correctly and hopefully with minimal damage done to walls, ceilings and floors. 7. Switch it on Switch on all computers, printers and other peripherals. 8. Connect the ICS host Go to the ICS host computer and make sure it is connected to the Internet. 9. Run the Network Setup Wizard on the ICS host To run the Network Setup Wizard on the ICS host, click Start -> Control Panel -> Network And Internet Connections -> Setup Or Change Your Home Or Small Office Network. Follow the instructions in each screen and press Next to continue. XP's Network Setup Wizard takes much of the pain out of setting up a home network. The Network Setup Wizard will guide you through: Configuring your network adaptors (NICs). Configuring your computers to share a single Internet connection. Naming each computer. (Each computer requires a name to identify it on the network.) Sharing the Shared Files folder. Any files in this folder will be accessible to all computers on the network. Sharing printers. Installing the Internet Connection Firewall to guard you from online attacks. 10. Run the Network Setup Wizard on all computers To do so: Insert the Windows XP CD in the first computer's drive. When the XP Welcome Menu appears, click Perform Additional Tasks. Click Setup Home Or Small Office Networking and follow the prompts. Repeat steps 1 to 3 for each computer on your network. Make sure you maintain an active Internet connection on your host computer as you proceed through this process. geekgirl.tip If you don't have a CD-ROM drive on one of the network computers, you can run the Network Setup Wizard from a floppy disk: While running the Network Setup Wizard on the ICS host computer, select the option to copy the Network Setup Wizard to a floppy disk. Once you've completed setup on the ICS host, take the floppy to the next computer and insert it in the drive. Double-click My Computer. Double-click 3½ Floppy (A:). Double-click netsetup.exe. The quickie XP network If you want a really easy networking experience and you have the hardware to support it, consider clean installing Windows XP on two or more computers. First install your network hardware (network interface cards, cabling, et cetera), then perform a new installation of Windows XP. During installation, XP will sense your hardware setup, ask for a name for each computer, and then ask which type of setup you wish to create. Select Typical Settings For A Default Network Configuration. That's it. Provided your hardware is XP-compatible, XP will create a LAN using the workgroup name MSHOME. Using your network Once you have your network up and running, you can easily access other computers on the network via My Network Places (click Start -> My Network Places). The Task Pane in My Network Places lets you access computers on your network and adjust settings. The Task Pane in My Network Places lets you view your network connections and view each of the computers in your workgroup (the workgroup consists of all computers on a network which share the same workgroup name ? by default, XP gives all computers on your home network the workgroup name MSHOME, although you can change this if you wish). When you initially open My Network Places, you'll see icons for the Shared Files folder of each of the active network computers. Sharing a printer With your home network installed, your PC suddenly gains all the advantages of the other PC's on the network. If you've been lusting after your sister's colour photo printer, you can now print directly to it from your own machine. Provided, that is, your sister decides to share her printer. (You might offer to let her share your laser printer in return as an inducement ? sharing works both ways.) To share a printer, on the computer which is directly connected to the printer: Click Start -> Control Panel -> Printers And Other Hardware -> Printers And Faxes. (Note: These steps will be a little different if you're sharing a printer on a PC running a version of Windows other than XP. For example, under Windows Me, you click Start -> Settings -> Printers.) Click the printer you wish to share. Click Share This Printer in the Task Pane. In the printer's Properties dialog, click the Sharing tab. Click Share Name and OK. Make a printer accessible to others on the network by sharing it. Once a printer has been shared you can access it from other computers on the network. To do so: Click Start -> Control Panel -> Printers And Other Hardware. Click Add A Printer. In the Add New Printer wizard, when asked whether the printer is a local or network printer, select the latter. In the next screen, select the option to Browse For A Printer and click Next. Select the appropriate printer from the list and continue with the wizard. Sharing files and folders Sharing a folder is even easier than sharing a printer: Open a folder (such as My Documents), click Make A New Folder in the Task Pane and name your new folder. With the new folder highlighted, click Share This Folder. In the Sharing tab of the Properties dialog box, select Share This Folder On The Network. Provide a descriptive name for the folder. This name should make it easy for others on the network to recognise the folder; it doesn't have to be the same as the folder name you selected in step 1. You can let other people on the network view and edit your files or view them only. If you want to protect your files from tampering, remove the tick from Allow Other Users To Change My Files. There are a variety of ways to access a shared folder. Here's one way: Click Start -> My Network Places -> View Workgroup Computers. Click the computer whose files you wish to access and then click the shared folder. You can create shortcuts to shared folders to make them easier to gdfgf
Sep 08, 2007 | Computers & Internet
Microsoft Windows XP Professional Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
