Question about RCA D52W19 52" Rear Projection Television
Problem with power up and then turns off shortly thereafter.
A month ago my RCA D52W17 turned off unexpectedly. I unplugged it and replugged it. The issue went away until today. The television will boot up if left to sit for a while after powering down. It will run for 5 to 15 minutes before turning off again. I have looked for cp150 to check for swelling and can't find it. I would like to know what board it is on and possibly where to find a replacement cap. Any direction is appreciated.
  • RCA Master
  • 8,617 Answers
The cap is located here the upper most capacitor inside the "u" shaped heat sink.on the board with the flyback which is the board on the left side of the cahssis's bottom boards
Posted on Feb 09, 2009
Wont power up,changed out power supply,same,used to come back on after unplugging,replugging..
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 13, 2015 | Televison & Video
RCA L37wd12 won't turn on. Red light is on but no reaction from either on button or remote. Used to be able to unplug then replug to fix. Now nothing. I've seen similar posts but no solutions. Any ideas?
This is a power supply problem and they are hard to find because they are not made anymore. I had to replace mine several months ago and it took me a month of research to locate someone who had one.
Dec 14, 2010 | RCA L37WD12 37 in. LCD HDTV
My 42 inch Sharp 1080p will not power up. It's only 6 months old, and a month ago it just powered off, and won't turn back on. Any suggestions...I thought maybe my grand children did something with the...
Check the power source?Try unplug,replug tv an hour later.Let the tv resetting itself back to factory setting.The tv should work now.No,LCD tv have common problems power supply board died alot.This tv is new,call Sharp for warrenty repair.
Sep 09, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
Not working
It sounds like 2 separate problems:
1) One of the cooktop lights may have shorted. Sometimes this happens and causes damage (repairable) to the control circuit board. Sometimes it will result in the lights or fan not working, or not turning on.
2) You may have a bad magnetron. See this FixYa solution.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | GE Microwave Ovens
My TN55X81 is showing the same problem.
Replace the IC's with STK 392-110T.
Toshiba has a Service Bulletin on this problem.
Aug 01, 2009 | Toshiba TN61X81 61" Rear Projection...
Tv wont turn on
try replacing the flyback 259296 and CP150 both items are available at the following link with free instructions.
Dec 20, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W17 won't stay on.
Possiblility include bad convergence cuircit. A component that is overheating and bad solder connections.. Technicians can use special equipment to read error codes... this will tell them the error that is shutting it down
Mar 13, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w17 hdvt rear projection Problem
If the light cycles on three time the micro is working but there is something shuting it down.a This is not clear cut it would need to be troubleshot. You need to call a tech.
Oct 29, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
134 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
